Old 28th February 2008, 10:04 PM   #61
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Great stuff! I have found similar improvements with those types of speaker mods. Very, very rewarding for the money spent.
Congratulations.
Simon
Old 1st March 2008, 05:29 PM   #62
Thomo is offline Thomo  United Kingdom
Thomo's Avatar
Glad to hear you're happy with your speakers Matthieu, you've inspired me to have a play with mine!
I want to replace a 25uF cap in my crossover, but I can only find 22uF, could I use this? If so what would the difference would it make to the sound? Would it restrict bass?
Sorry for being a little o/t.
Cheers, Lee.
Old 1st March 2008, 06:20 PM   #63
Malefoda's Avatar
Send a message via MSN to Malefoda
Don't bother and take it as a chance to mix caps!
My advice:
one ClarityCap SA 22µF and one Mundorf Supreme in // 2.7µF or 3.3µF if needed: that's a very rewarding match most of french DIY's folk said.
edit: I've had constant music today, away or sittin'n enjoy: woww! So much space! Like I'm in in a bigger room! And much more details flow with ease! This is a must be done... more than a clock in a CDP!
Old simple TT, cheap CDP with wise mods, Class T amp at its best: music!
Old 1st March 2008, 07:39 PM   #64
Thomo's Avatar
Ah, I didn't think of doing it with one good cap and then one uber cap. I was looking at using BG AC's 10uF + 15uF. I wonder which will be the best combination. Also, fitting them in may be a problem.
Just thought I'd attach a pic if anyone's interested. No more o/t I promise.
Regards, Lee.
Old 2nd March 2008, 05:31 PM   #65
SimontY's Avatar
Lee,
My advice is:
1) Cut your nails.
2) Parallel some caps as per Matthieu's advice.
What is that large cap doing in your speakers?
Simon
Old 30th March 2008, 03:15 PM   #66
Malefoda's Avatar
Hi there,
wanna know if I go for a 5W resistor to replace the 5W instead of a 10? Any improvment in using a 10W instead of OEM 5?
Thanks,
Matthieu
Old 30th March 2008, 03:31 PM   #67
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally posted by Malefoda
Hi there,
Thanks,
Matthieu
Theoretically better temperature stability (less ppm) for given dissipation. I doubt you will hear an improvement if not of better construction and material quality too (Mills etc). It will certainly not hurt.
Old 14th May 2008, 05:10 PM   #68
Malefoda's Avatar
1R65 instead of 1R5, too much excited highs, I've tried 1R8 wich killed the highs... 2x 3R3//3R3 are in. A bit less green stuff back panel and damping feet removed and cabinet held on foot with Blu-Tack instead of these round small pieces of rubber : whoowwww !
Bass are strong and well hold, medium is very detailled now!
At a glance:
Filter upgrade: better dynamics, better matter and better details in half top,
damping upgrade : better control of half bottom,
Blu-Tack and OEM rubber feet removed : strong bass
Old 15th May 2008, 10:52 AM   #69
SimontY's Avatar
Blu Tack is good
Old 20th May 2008, 03:59 PM   #70
Malefoda's Avatar
Pro singers enjoying Quad's song!
The guests, dressed in smoking,
lovley CDP and integrated !
The Quad are so shiny !
Most recommended Quad 33 upgrade ? gilwe Solid State 3 24th April 2009 02:21 PM
Quad 405-2 OPA134 Upgrade - Resitors R7&R8 Electrobumps Chip Amps 4 16th September 2008 10:17 AM
Quad 405 strange noise post upgrade lance_the_boil Solid State 1 14th October 2006 09:36 AM
power supply capacitor upgrade on Quad 405-2 sberube Solid State 21 24th March 2006 07:05 PM
Quad 67 CD clock upgrade? Zombie Digital Source 4 18th October 2004 09:59 AM
Page generated in 0.10770 seconds (79.72% PHP - 20.28% MySQL) with 11 queries
