I have been listening to music on a bush mini system any one from britan will know that this is one of the cheapest and worst makes so anything will be an improvment. The amp I am going to use is 60w @8ohms.
I have tools and wood working skills so making the cases wont be a problem. I am going to use the Linkwitz-Riley Electronic Crossover. High Pass - frequency is approx. 310Hz Low Pass - frequency is approx. 310Hz I would like the speakers not to be floor standers more like shelf speakers. Does any one have some designs, as many poeple I am skint so I dont want to pay more than £100 if their are realy nice £150 (this dosn't include cost of wood, paint, skrews or anthing like that just the drivers). |
#2 |
I can't understand why in the first place why you would buy such an awfully made system,the speakers are made so poor,that they either fall apart very easily and blow up very easily.
Those cheap cabinets are made of hardboard,plastic and thin chipboard.With drivers which are so badly made you would normally find at a car boot sale or in old cars at the scrap yard. Now to help you find some drivers for not much money. 2x Audax AP210Z0 8 inch bass/midrange,70w rms,8 ohms,29hz-6khz,sens 90db at 1w 1m. Cost £26 each inc vat 2x Motorola/CTS piezo horn tweeter KSN1165A 200w rms/400w music [includes built in protection circuit] £12 each inc vat [No crossover is needed with the piezo tweeter] If you decide to buy these,plus the extras[wire,grille cloth,terminals] go to www.maplin.co.uk these two products are from maplin electronics,either go to many of there shops or order and buy online. |
#3 |
1. I id not want to buy such a bad system it was the first one I ownwed I needed it so I could listen to music and at the time i didn't realise there was such a big diffrence between sound systems
2 How do you hook up the tweeters with out a crossover |
#4 | |
wire the woofer in series with it's crossover components, ant this all in parallel with the tweeter |
#5 |
Dude (tomj)
Your story/situation is exactly the same as mine!!! cool. I dont feel so alone (sob, sob) How far have you got with the speakers? I have a sony portable stereo and it really sounds crap. I also like the stylee of your budget, are you a student too? If you have any progress please keep me posted (e-mail if you want) so I can get a pair on the go. Take it easy folks Calum |
#6 | |
frugal-phile(tm)
If you are building a small 2-way and using this as the XO, then you should be looking at a 6 or 8" woofer and a 2 or 3" mid-tweeter (full-range). Fostex FE83 or one of the TangBands (lots of info on the forum about the W3-871s). Since you are in Europe there could well be some suitable Vistatons or Monacors. HiVi Research also have some this size. You could also look on eBay for these kinds of mid-tweeters. I have some little Telefunken ovals that were used for this purpose, and have sold a couple other prs. A little more off-the-wall would be a set of 25 or 35mm HK Odessey drivers (as found in iMacs/eMacs etc). These would likely have to be gotten as service parts (that is how i got my 25mm ones -- the 35mm came with my wifes Cube) dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#7 |
Bull
If I got those drivers you sugested (audax, motorola) what kind of box should I be making for those, what xo design and do ya reckon they will sound good? I know its a lot to ask but i really dont have a clue. Am learning though. Calum |
#8 |
Calum,
I am a student as well at the moment, I have not started these speakers yet. When i do i will keep you posted on the progress. |
#9 | |
I see you are still a regular here, so I'd like to seek your advice on the above drivers. Of course, other readers are free to post their two cents (tuppence? euros?). I haven't seen an on-axis response curve for the CTS tweeters, but the Audax 8" looks pretty ragged above two KHz or so. I think that a 12 dB / octave LC filter in front of the Audax would help with this. Maybe two or three KHz? The CTS piezo is rated at 92 dB sensitivity, a little more than two dB hotter than the Audax 8". Any specific recommendations on padding the piezo down a bit? Would the piezo benefit from any filter circuitry? Specific question - if the LP filter in front of the 8" driver was constructed for -3 dB at 2250 Hz, what (if any) would be recommended to reduce the piezo's level and / or smooth its response. Thanks all - I read all I can, but I always benefit from the experience of those who have actually gotten the slivers and the blisters. dooper |
#10 | ||
frugal-phile(tm)
dave Quote:
| cheap computer speakers | LightwaveDude | Multi-Way | 6 | 23rd May 2006 08:48 PM |
| Are cheap speakers worth? | wxn | Multi-Way | 3 | 11th July 2004 11:19 AM |
| Building DIY Speakers on the cheap | Phatman91624 | Multi-Way | 15 | 28th May 2004 05:44 PM |
| CHEAP HT speakers help | bhg41088 | Multi-Way | 4 | 14th May 2004 01:16 PM |
| Page generated in 0.13078 seconds (85.54% PHP - 14.46% MySQL) with 10 queries |
