Old 7th January 2008, 01:14 AM   #11
frugal-phile(tm)
planet10's Avatar
Here is the XO pic with parts drawn in (i made a few assumptions to cover the missing stuff)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 7th January 2008, 01:17 AM   #12
ccdoggy is offline ccdoggy  United States
Send a message via AIM to ccdoggy
That is exactly what it is.
So with the T/S and box volume (im sure i can figure out the port tune then) I can create a "good" crossover, yes/no?
I guess im just not clear on where to start and what to do.
I appreciate all the help in clearing this up.
Old 7th January 2008, 01:17 AM   #13
frugal-phile(tm)
planet10's Avatar
And a redrawn XO map that is a bit easier to see what they are doing (it is the same as the one posted earlier)
It is a series XO and somewhat related to the diaural XO topolopgy.
dave
Old 7th January 2008, 01:19 AM   #14
Actually now that i look at the other speaker It says " Licensed by DiAural" on the back.
out of curiosity on a scale of 1-10 what would you make of this crossover. would it be worth replacing?
Old 7th January 2008, 01:45 AM   #15
frugal-phile(tm)
planet10's Avatar
To my mind the whole DiAural thing is just a way of saying "our XO tech is patented". A properly done series XO (which would be a development on the diaural) would be better IMHO. You would take the air core inductor, toss everything else and put a cap in shunt across the woofer.
http://www.t-linespeakers.org/tech/filters/diaural.html
dave
Old 7th January 2008, 06:44 AM   #16
I would then still need to compensate for the sensitivity of the tweeter vs woofer, which is 91db for the tweeter and 86db for the woofer.
Sorry for the basic questions, im still trying to grasp and comprehend the uses.
Old 7th January 2008, 09:14 AM   #17
Dave,
I think one end of the 7.5 ohm resistor is connected to the -ve of the tweeter, not the input?...if so, it's easy to convert it to a 'normal' series xover (with BSC provided by the 2nd L) by replacing the resistor with a cap. Of course, then the tweeter would then need to be padded.
Whether changing the xover would make much difference depends on the drivers' responses outside the xover passband,
do you know what model numbers they are Ccdoggy?
Pete McK
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 7th January 2008, 09:58 AM   #18
frugal-phile(tm)
planet10's Avatar
Thanks for the QC,.. i have fixed it.
That would change the low pass to 2nd order from 1st as well... the series iron-core inductor could be shorted to bring it back to 1st order.
It would certainly be simpler with less energy loss in that inductor and in the shunt resistor.
dave
Old 7th January 2008, 06:29 PM   #19
The tweeter is a Vifa D26NC-15-06 and the woofer is a Vifa BC14SG49-08.
T/S specs:
Tweeter:
VC:26mm
dB:91
W:100
Z:6
Re:4.6
Le:.05
Ce:2.4
Fs:1500
Vas:-
Qms:1.5
Qes:2.3
Qts:.90
Xmax:0.3
Woofer:
Re: 5.55
Le: 0.6
Fs: 53
Qms: 2.73
Qes: 0.53
Qts: 0.45
Mms: 7.8
Vas: 10.5
dB: 86
Vc: 25mm
Bl: 5.2
Old 7th January 2008, 07:19 PM   #20
http://madisound.com/pdf/Swifty.pdf
Is a good place to start for a new crossover, mid/bass section at least.
The treble section needs a little fiddling due to the 4R tweeter and the lack of known sensitivity.
/sreten.
Non existing musicians Netlist Music 5 30th December 2011 11:15 AM
Determine crossover frequency of existing XO focal7C Parts 1 26th May 2008 09:07 AM
How to remove existing wax andy2 Multi-Way 2 26th May 2006 02:19 PM
Effects of modifying an existing passive crossover geolemon Car Audio 13 15th January 2006 08:06 AM
Copyright ©1999-2013 diyAudio
