Old 4th January 2008, 07:52 PM   #1
sdclc126's Avatar
Default Filter for Peerless 830896
Greetings!
I am going to be using these 3" widerangers for HT surround as well as serious listening ambience:
http://www.madisound.com/catalog/pro...oducts_id=8305
I am wondering if I should notch the peak in the 10K region - it appears to be fairly significant.
Any thoughts would be greatly appreciated.
And a belated Happy New Year to everybody.
Soft Dome
Old 4th January 2008, 08:15 PM   #2
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
You're right, it does look fairly significant, and will likely melt your ears .
If I were using this driver, I'd want to cross it to a small tweeter at about 4-5kHz. The Aura NT1 looks like a good candidate for $9.
Old 4th January 2008, 09:54 PM   #3
sdclc126's Avatar
I want to get away with a single driver with minimal filter - I decided to order the Aura NS3-193-8A1 - more expensive and less efficient than the Peerless, but it has a smaller peak lower down that I don't think will need a notch, and the next one is up at 15 which I think for my needs will be pretty much out of the way.
Soft Dome
Old 9th January 2008, 12:01 AM   #4
DcibeL's Avatar
Excellent choice.
Old 9th January 2008, 12:07 AM   #5
sdclc126's Avatar
Thanks -
They arrive Friday!
Soft Dome
Old 10th January 2008, 04:49 PM   #6
Hi, wishful thinking, /sreten.
Old 11th January 2008, 03:37 AM   #7
sdclc126's Avatar
They look almost identical to me, only at different dB levels. But I'm no expert.
Filter can come later if I feel it's needed.
Soft Dome
Old 11th January 2008, 03:53 AM   #8
DcibeL's Avatar
Looking at the transfer curve you can see exactly what the filter does; it helps flatten the two lumps in the frequency response. The improvement I believe will be fairly significant, though the filter parts could easily end up costing the same amount as the driver itself.
The power of Science compels you!
Old 11th January 2008, 03:55 AM   #9
sdclc126's Avatar
For HT and ambience I'm not too worried at the moment. If these were going to be mains...
Soft Dome
Old 11th January 2008, 09:50 AM   #10
Default Re: Filter for Peerless 830896
Greetings!
I am going to be using these 3" widerangers for .... serious listening ambience:
Well you asked the question, and Zaph does not gild the lily.
/sreten.
peerless xxls sealed -vs- peerless xls with passive radiator Naudio Subwoofers 8 23rd March 2008 09:00 PM
need help wana change 60-Hz twin-T notch filter to 279 Hz filter prorms Solid State 0 9th February 2008 11:38 PM
active filter from rod elliot and sub filter questions wuffer Parts 0 2nd October 2005 01:12 PM
Peerless kit PP33 filter schematic ??? AudioGuy Multi-Way 0 27th January 2004 10:31 PM
Whats the difference between the Peerless 831916 and Peerless 850122 SkinnyBoy Multi-Way 9 12th June 2003 03:11 PM
Page generated in 0.09573 seconds (78.93% PHP - 21.07% MySQL) with 11 queries
