Speaker choice for line array
Old 21st December 2007, 12:39 AM   #1
MPM is offline MPM  United States
Default Speaker choice for line array
Roger Russell's IDS-25 is an awesome looking speaker to me. I'd like to build a set similiar to his but the drivers he chose are rather expensive individually for a 3.5" driver much less the cost for 50 of them.
Roger Russells site
http://www.ids25.com/index.htm
The driver he uses for the IDS-25
http://www.madisound.com/catalog/pro...oducts_id=1616
Would the following driver be an acceptable substitute for my own version of a 25 driver full range line array? Cabinet would be similair construction.
http://www.madisound.com/catalog/pro...oducts_id=8305
I'm aware of the inherent problems with line arrays and I can live with that so please don't suggest other speakers to build or tell me all the bad things about line arrays.
Thanks,
Marshall in Alabama
Old 21st December 2007, 01:01 AM   #2
Brisso57 is offline Brisso57  Australia
Brisso57's Avatar
Default Re: Speaker choice for line array
Roger Russells site
Thanks,
Marshall in Alabama
Hi MPM,
Have you seen the Apex Jr site?
www.apexjr.com/speakerstuff.html
I too have been toying with constructing a pair of LA's (& yes, I too get tired of hearing well-intentioned advice from well-intentioned people!).
I have a couple of projects to complete before I get to building my arrays, but the items of interest at Apex Jr would be the M&K 3" FR drivers and the el-cheapo tweeters (which have had some good reports ... as long as they're not crossed too low.)
My recommendation is to buy a number (6) of the cheap M&K FR's. At 12 ohms each, you could parallel 3 series-pairs, returning you to 8 ohms. Try these out in a temporary baffle, and if they seem OK, buy more and proceed.
If you do the above, pls also tell me what you find! ... as it's what I intend to do when I tidy up other projects.
cheers
Doug
A speaker-builder's parable: "That burned down, fell over, then sank into the swamp. But the fourth one stayed up. And that's what you're going to get, Lad, the strongest castle of all."
Old 21st December 2007, 01:09 AM   #3
Thanks Brisso57. I'm familiar with ApexJR and the B&K 3". I'm still just thinking about the line arrays and would probably buy the drivers in a few installments so I can hide the purchase from the wife if I go ahead with the project.
Old 21st December 2007, 01:20 AM   #4
Brisso57's Avatar
Hiding a pair of line arrays is like trying to hide an elephant. You need SALESMANSHIP!
Old 21st December 2007, 01:30 AM   #5
If they sound good she would possibly let them into the living room since the footprint will be relatively small. I currently have 4 floor standing speakers as my mains and surrounds. She accepted those for the small footprint, sound and the lovely piano black finish . Maybe she loves me a little bit also.
Old 21st December 2007, 02:45 AM   #6
Zarathu is offline Zarathu  United States
Default line array
go with 3.5 inchers and Dayton neo's, and couple of big 12's, then use an electronic crossover and trip amp the system:
http://pub48.bravenet.com/photocente...31&album=48032
Youth is wasted on the young.
Old 21st December 2007, 03:47 AM   #7
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
I like'em. Not so sensitive like mine (I used Infinity Reference 4.5" as midranges), but lower Fs and smaller size. If I knew about them I would probably save some money...
Speaking of "Her Approval", I put mine inside of the wall around the screen; she likes that!
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 21st December 2007, 06:00 PM   #8
DaveM is offline DaveM  United States
DaveM's Avatar
Take a peek at the Zalytron website. They have several designs for line arrays. I have a set built with the Axon 6s1. They are a very nice coated paper from Peerless of India driver branded for Axon. They are $180 for 10. If you are looking for some of these I am considering getting rid of mine.
Old 21st December 2007, 07:17 PM   #9
sdclc126 is offline sdclc126  United States
sdclc126's Avatar
MPM -
In terms of the Vifa vs. Peerless drivers - they are both a little ragged at the top end - rising response for the Vifa and a marked peak for the Peerless. If you go with either one I would recommend a little filtering in those areas, namely a notch for the Peerless.
I like the very broad, smooth band in the Peerless myself - I didn't even know about these until I saw your link - I think I will get these for my surround speakers I'm building, as well as the small speakers I'm building for my mini HT system in my bedroom.
For a very small footprint, take a look at this P.E. project if you haven't seen it - perhaps not for the same drivers but for alternate enclosure ideas.
http://www.partsexpress.com/projects...1/Kuze3201.cfm
Also, I'd still want to use tweeters to get smoothly up to about 15K or so. Just my 2c.
Soft Dome
Old 21st December 2007, 07:40 PM   #10
dantwomey is offline dantwomey  Canada
I bought a LA kit from Rick Craig at Selah Audio. This kit was very complete with all fasteners, wire, terminal cups, drivers, and crossover parts included. All I had to do was build my own cabinets. Here's a few pics:
One picture of the final assembly.
My finished Linus III's
Merry Christmas,
Dan
Speaker choice for line arrayHide this!Advertise here!
ST324 Selenium a good choice for line array tweeter? GuyPanico Multi-Way 0 10th June 2006 09:04 PM
Another Line Array Speaker Thread dhenryp Multi-Way 35 3rd December 2005 05:59 PM
Moved: Driver choice (Belgium) and LF design considerations for 50€ Line Array Cordraconis Full Range 4 1st April 2005 02:52 PM
line array speaker selection.... onis_uk Multi-Way 8 4th August 2004 08:05 AM
