Old 20th January 2008, 01:03 AM   #31
jwmbro is offline jwmbro  United States
jwmbro's Avatar
Hello,
by pair I meant the large and the small driver, not two sets of coax.
Wouldn't coax make the vertical dispersion go crazy though, and cause ceiling and floor reflections?
Old 20th January 2008, 03:07 PM   #32
Robh3606's Avatar
"Wouldn't coax make the vertical dispersion go crazy though, and cause ceiling and floor reflections?"
It shouldn't and in some cases the dispersion is the same at any angle. Depends on the driver. Many have the tweeter driving a horn or waveguide that determines what the directivity is. The center I am using has a horn that limits the vertical dispersion. You need to look at the coax drivers you would want to use to see how they are set-up.
Rob
Help with Sub Drivers for my 2 Channel Full Range the joz Multi-Way 18 10th September 2008 09:13 PM
SNR/Dynamic range worsens in low frequency range. percy Digital Source 3 1st June 2006 12:41 PM
Full-Range bipolar centre channel planet10 Multi-Way 9 6th June 2003 08:35 PM
Foam blocks between 2 Tang Band 3" full range on a small center channel The Paulinator Multi-Way 5 27th March 2003 05:04 AM
Page generated in 0.06900 seconds (65.90% PHP - 34.10% MySQL) with 11 queries
