Old 17th December 2007, 01:47 PM   #1
Default Help with Adire 281 TL design
Hello all!
I've been lurking here for a while and recently registered. Of course, now I am hoping to lean on the experience of the folks here to help mw with a problem I've encountered.
I recently built the Adire Audio 281 speakers in a Transmission line version. The Adire 281's have been noted for their strong bass performance and have been considered a strong speaker for home theater as noted in this audioxpress review . Unfortunately, the pair I built have very poor bass response below 100hz, dropping off to -12db at 50hz. I've taken some measurements using RoomEq and my Radioshack SPL meter and they are shown below.
I'm not smart enough to diagnose the problem and was hoping to provide the forum with the relevant info to see if there's anything I can check / do. Any help or ideas would be greatly appreciated.
Thanks,
Russell
I've included the cabinet and crossover plans below.
281 cabinet
TL line stuffed with 24oz polyfill in 4.5" section, 18oz in 3.5" section, 6 oz in 3" section.
281 XO
281 TL (right channel measured in room ~3' away)
Solid Black line is RS SPL calibration line
Dotted black line is sound card calibration line
Blue line is corrected speaker line
Previous speaker (wharfedale modus 1.6 right channel measured in room ~3' away)
Dotted black is sound card calibration line
Purple is corrected speaker line
Old 18th December 2007, 07:08 AM   #2
Shaun is offline Shaun  South Africa
Shaun's Avatar
Hi Russel
How did you go about determining the box dimensions? Are you aware of Martin King's work on transmission lines?
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Old 18th December 2007, 07:17 AM   #3
frugal-phile(tm)
planet10's Avatar
Designed by Dan Wiggins using classic methodology.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 18th December 2007, 07:31 AM   #4
Shaun's Avatar
Dan Wiggins... OK, check that. But what do you mean by "classical" methodology? Recently, that has become a swear word around these parts. Check the Clarity on Seas Thor Kit* thread, and you'll understand. Martin's spreadsheets come closest to predicting final as-built response.
One thing to inspect is the amount of stuffing inserted. Too much can overdamp the back wave. Try experimenting with removing some (or a lot).
Edit: *the action starts at post #10
Shaun Onverwacht
Old 18th December 2007, 07:47 AM   #5
frugal-phile(tm)
planet10's Avatar
And i hope that i played a role in making that so Classic is what we were doing before Martin (and George) came along and showed how much more could be gotten out of a QW box.
MJK should always be consulted when doing a TL.
I've been chatting with Russell by eMail, and have made a few suggestions already in the hopes of saving him from having to start over on the boxes.
One of the problems is that they are very heavily stuffed (i haven't checked Russell's density calcs, been busy) and with them all closed up he has no way of pulling it out and playing.
dave
Old 18th December 2007, 07:57 AM   #6
Shaun's Avatar
Originally posted by planet10 And i hope that i played a role in making that so
Oops!
OK, you're on the ball. I did not notice that it was you who replied! LOL!
Shaun Onverwacht
Old 18th December 2007, 08:32 AM   #7
GM is offline GM  United States
GM's Avatar
Default Re: Help with Adire 281 TL design
Originally posted by trpltongue
I recently built the Adire Audio 281 speakers in a Transmission line version. The Adire 281's have been noted for their strong bass performance and have been considered a strong speaker for home theater as noted in this audioxpress review .[/IMG]
Greets!
Well, after browsing the assembly manual and review as well as doing an approximate sim using MJK's software, you got exactly what DW said you were getting, a ~anechoic response down to 35 Hz, i.e. a ~IB response in a relatively small cab. If you wanted the Kit281's potential strong bass response, then you should have built the vented version that was reviewed.
Note that this isn't a TL per se, but a Daline like the Seas Thor.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 18th December 2007, 04:23 PM   #8
Thanks to all for the great replies!
I have been working with Dave and Dan via email and as mentioned, I have no real ability to remove all the stuffing. Right now I have ~ 1.8lb/cuft of stuffing as per the 281 design manual. From speaking with Dave and Dan, that seems a bit overstuffed.
GM,
I am admittedly very new to TL design, but based on the descriptions of the vented and TL design, I thought the TL design would reach somewhat lower, flatter than the vented design:
Vented:
anechoic response to 45Hz with a box tuning of 28Hz
typical in-room extension into the 30hz range
TL:
anechoic response to 35hz with a line tuning of 37Hz
typical in-room extension to 28hz
Either way, I didn't expect such a sharp falloff at 100hz.
Old 18th December 2007, 05:04 PM   #9
*edit to above
I just spoke with Dan and he informed me of where I was misunderstanding I thought that the TL would have a -3db response at the F3 of the driver, but Dan has informed me that the typical TL response is -10db at the F3 of the driver, which is spot on what I'm getting.
I will still try removing the stuffing from the first line section as much as possible and listening, but if all else fails I will try blocking the line terminus and porting the rear to see how it sounds.
Oh the joys of being a rookie
Old 18th December 2007, 05:15 PM   #10
Scottmoose's Avatar
Seems a rather strange design to me. Leaving aside the discontinuities, it seems over-long & lacking sufficient volume to get much useable LF gain. And that kind of stuffing density is excessive in the extreme IMO for almost any TL.
This is the cabinet with no damping applied, in the TL sections sheet & the drivers paralleled for the sake of the sim.
Active UcD, Adire & Usher design. ben_scammell Class D 4 4th January 2006 06:22 PM
Adire's new horn design for the Tempest leadbelly Subwoofers 2 1st September 2004 05:44 PM
Low Q sealed design for Adire Tempest Glenn Booth Subwoofers 18 7th August 2004 08:40 AM
My Adire's dome406 Multi-Way 1 15th July 2004 06:20 PM
Page generated in 0.12852 seconds (80.02% PHP - 19.98% MySQL) with 11 queries
