Hi I'm planning to build a 3-way speaker system.
I want to know as to which of these two sistem speakers would be best. Please help Vifa Woffer PL26wr09-8 10" Midrange PL11mh09-08 5" Tweeter XT25TG30 Peerless HDS Woffer 830869 8" Midrange 830872 4" or 832873 5" Tweter XT25TG30 |
#2 |
What crossovers do you have in mind?
#3 |
Im think use 300 hz for woofer-midrange and 4khz for midrange-tweter
#4 |
I would pick Peerless and not the vifa.
Woofer 830869 8" Midrange 830872 4" Tweeter XT25TG30 The 4" would be better at 4000hz than the 5". Looks like a promising HQ driver pick, maybe someone else allready built one just like it? |
#5 |
Hello Emoretti, I can tell you that
For the vifa Woffer PL26wr09-8 10" ,You can get deep bass more than Peerless HDS Woffer 830869 8" For the Peerless HDS Woffer 830869 8",You can get transient respond better than 10". And the wooffer,You can choose 300 HZ that you want to cut off low frequency. The both wooffer can work well. And if you choose 300 HZ The Midrange that you use. The resonant frequency for it must be lower than 175Hz. The hign pass filter ,you choose that's 4000 Hz. I don't know thefrequency respond for the drivers but I ever seen many midrange drivers for two brand last year ago. I remember that the bandwith respond is wide. At 4000 Hz,It 's far from break up cone point. I think that you can it's well at 4000 hz for the Midrange and tweeter drivers. If I build I will choose: Peerless HDS Woffer 830869 8" Midrange 830872 4" or 832873 5" Tweter XT25TG30 Thawach
| Loudspeakers | Gary Hubbard | Multi-Way | 4 | 19th July 2009 04:00 PM |
| Loudspeakers 101 | Moondog55 | Multi-Way | 8 | 15th June 2008 02:24 PM |
| EMI LE4 loudspeakers | Deckman | Swap Meet | 1 | 22nd August 2007 08:48 PM |
| Loudspeakers | Vivek | Everything Else | 7 | 27th March 2001 04:14 PM |
| Page generated in 0.07183 seconds (73.98% PHP - 26.02% MySQL) with 10 queries |
