Hello, I am building my new center channel speaker using two seven inch woofer and one four inch, maybe two four inch mids and one tweeter. What I am not sure about is should I put the four inch mids in a calculated enclouser or just make sure they are seperated from the six inch woofers. I intend to cross the mids in about 350 or so and rolling them off around 2500-3000 hz. Do you think to get good performance at 350hz that this would require a calculated enclouser? or would that be pointless when only going down to 350hz? Slope is electronic 24db per octave for all drivers.
Thanks, Dallaire |
#2 |
Hi Dallaire,
A couple of things to remember. The mid drivers must be acoustically sealed from the woofers otherwise when the woofers pressurize the cabinet, the mid cones will get pushed out. Secondly, if you're crossing over at 350Hz then the mid cabinet needs to ensure good driver performance to at least 175Hz maybe even 80Hz if you're using a low order XO. However, a small driver with a low Vas (most are) won't take up too much volume in the cabinet. I heard of people gluing tupperware over the mid to good effect. Personally, I make a wooden box for more stiffness. One option: design the mid box to give the required mid high-pass crossover response and save some caps/inductors (although the bass power would still be dissipated in the mid driver, limiting headroom.) |
#3 |
Hello, Iain thanks for the response. I will be using a dedicated amp for each size of driver with a 24db per octave electronic x-over to seperate all speakers, all Marchand Electronics stuff xm1's to be exact. The drivers finally arived today. So I will start to break them in and begin testing parameters this weekend. I was going to seperate the mids (inside the cab.) using a length of thick cardboard tubing and cut a circle with plunge router for end of mid enclouser. But what I wasn't sure about was if I needed to make the enclouser a specific size so the four inch mids could perform down to 350hz, kind of like you need to make for the six inchers I'm using for the low end part. Also don't know for sure, now that you mention it if I should'nt make the cross point higher on the six to four inch driver, pretty steep slope but not sure. Did not want to cross over in the critical voice range is what I read at Rod Elliots site.. Although six inch woofers do go pretty clean trough to about 1K.
Speakers Peerless HDS Nomex 6.5 Two Peerless HDS PPB 4.0 Two Scan Speak 9500 Tweeter Ported enclouser Amps Rotel Thanks, let me know what you think? Dallaire |
#4 |
Have you already bought all the drivers? You don't need 4" mids with 6.5" woofers - you can cross the woofers directly to the tweeters.
But either way it sounds like you're putting a great system together.
Soft Dome |
#5 |
Speakerholic
If you're in the mood to build test boxes you might want to consider the use of an open back mid. It is isolated from the woofer box but is open at the back. Personally I really like the sound. A mid in it's own enclosure tends to sound boxy to me.
The 6.5" mids here are like that |
#6 |
Speakerholic
open back mid
#7 |
Speakerholic
On second thought that might not work. The open back "tube" isn't going to be long enough in a 6.5" woofer box to allow for a 350Hz XO. Mine is XO'd at 500hz.
#8 |
I have kicked around every type of driver complement I could come up with that would suit my needs. So I decided on using a three way because I've read if crossed electroniclly and each driver size having its own amp that great things could happen! time will tell, currently I have Diffinetive Tech everything. My mains are D'appolito array's with two 6.5's and one 1 inch tweeter all vifa drivers D.T. has used and I think they are "ho hum". I did bypass the factory passives and they do sound twice as good!!! but it seems I have achieved all the performance these drivers have to offer, mid priced at best, not that price makes a good driver, but it does seem to play a role to some extent.
Anyway, the open back approach may be a bit involved for me, carpentry speaking. So I will just try my best at measuring the mids and try to find a suitable enclouser size and conf. I will test mid enclouser prior to final design, for response I mean, using test mic and R plus D program, after all I think it is as much fun to design and build as it is to listen Thanks agian, Dallaire |
#9 |
It's been a while since I designed cabs so please, anyone, correct me if I go wrong here.
What I see in the specs is a 4" driver F3 at 100Hz, Qts of 0.54 and a Vas of 3litres. Cal is right, these are a good candidate for open baffle and you'll get response down to the 100Hz F3 with a Bessel response (i.e. perfect transient response, minimum group delay, nice!) I haven't played with OB (yet) so can't really comment but there is a lot of good feedback on this site. An enclosure for these would be pretty easy. Even a 3 litre box (pretty small) would only raise the F3 and Qts values a little bit so I think you'll be fine. Worth plugging into some design S/W if you have it. The tube idea is fine - make sure you seal all joints well. 24dB/oct means the driver is out of the picture (<1dB) by an octave below XO so it's all looking very good - like you designed it that way! ![]() afterthought - the 0.5 Qts will roll off very gently and start much higher than the F3 point. You may be better off (in XO performance) by raising the Qts to 0.7 (Butterworth - maximally flat) by using a smaller box and this would get a better XO integration. |
#10 |
Iain, you are correct on the IB setup. I did some testing this morning and found the calulated enclouser was nice and flat plus or minus one db, only problem with my tube enclouser was the fact that the low end was not there very well. I removed the "cap" at the end of the tube and the low end just opened up very nice! So my design now has changed to an open back mid enclouser, I am glad for this forum and educated people on the subject, like yourself! I tried to different quarter inch masonite baffles, just a "mock ups" to see edge effects, think I have this worked out now.
Thanks again, dallaire |
| Which amp for speakers with a Fountek Neo Pro 5i and 12 inch woofer | boidos | Pass Labs | 1 | 24th June 2009 09:10 AM |
| Vifa 8 inch woofer | MTruslow | Multi-Way | 1 | 8th January 2009 02:24 AM |
| 15 Inch/38cm PA (sub)woofer | tubee | Subwoofers | 10 | 23rd June 2006 09:56 AM |
| Best 15 inch Woofer around 500rms?!?! | WhiteBoyChriss | Multi-Way | 19 | 4th November 2002 12:29 AM |
| Page generated in 0.14651 seconds (76.15% PHP - 23.85% MySQL) with 11 queries |
