#21 | |
Custom Title
Can it? Do you know how much of a role the aluminum baffle plays in heat dispersion, seeing as these are power hungry? Would there be a better energy transfer from driver frames to aluminum vs. cement perhaps? It certainly seems like a heck of a little speaker, but I agree- nothing that would be THAT difficult to replicate. Just be careful with absolute comparative statements. Cement might be a worse solution.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#22 |
Certainly the speaker can be replicated for less than $20K! Shows you what kind of insane markups there are out there. It can be replicated for maybe 15% of the retail price, maybe less. What a huge waste of money to buy retail in this category, whatever your budget is.
I must say I'm intrigued by the woofer - would be nice to see some measurements.
Soft Dome |
#23 |
AFAIK All exclusive brands of speakers are using custom modified drivers .They may not be better than stock ones but they almost always little different -good luck finding/buying those drivers. How do you know that pictures of interior show all the details ?You'd need to use the same stock of material to build enclosures with the same technique and glue to get identical results ,than you would have to tune crossover (how do you know that each pair is not matched together)
I'd wait a little and buy used for half price or less. I've yet to hear a DIY speaker worth more than a wood it was built from .regards.l |
#24 | ||
#25 |
Nice DIY speaker, which TV crying for speakers?
regards zeoN_Rider |
#26 | |
Most frames have very little to do with thermal exchange. Because of that the baffle is rather meaningless thermally (except for converting vibration to heat - which wouldn't have much meaning as far as heating is concerned). The really important part here is a tight coupling of driver frame to baffle, and removal of vibration from frame (while limiting vibration being transmitted back to the frame delayed in time). The driver could be coupled as tightly to the cement baffle as to an aluminum baffle. Aluminum would be able to more quickly remove vibrations.. BUT would also transmit vibrations back to the frame more quickly. Cement however would only be slightly slower to remove vibrations, but (especially with some aggregate) return fewer vibrations - and likely considerably fewer.
perspective is everything |
#27 | |
Soft Dome |
#28 | |
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#29 | |
Custom Title
This is all fairly much esoterica, but I'm just saying- cement might not be better, the Al might be the superior design choice. Not *IS*, *MIGHT BE*.
#30 |
Dcibel
Cool speaker ,I bet it sounds more coherent than typical DIY project which usually consist a best most fashionable drivers money can buy ( why settle for less ??) panzer tank enclosures and latest foil inductors /expensive caps to ensure that result will be second to none. (well in that case Magico Mini is a really a good object of DIY interest ).As to why I post on the subject I thought that topic of this thread is how to clone sound of Magico Mini which I find not realistic /possible. But since most here feel they can certainly do better (which actually is possible) back I will go to my drawer
| the Very Mini Magico Mini | zei | Multi-Way | 7 | 11th February 2008 09:10 PM |
| "compact loudspeaker factory visit from "magico mini" thread | Nanook | Multi-Way | 2 | 4th January 2008 08:30 AM |
| Magico | zx3chris | Multi-Way | 8 | 6th August 2003 02:00 PM |
| Page generated in 0.12172 seconds (85.11% PHP - 14.89% MySQL) with 11 queries |
