Old 7th December 2007, 02:50 PM   #1
Default Do I need a router?
I've seen posts suggesting that a router is one of the most important tools for speaker building, but I'm still very reluctant to buy one.
I'm thinking of building a sonotube powered woofer to save some money, but if I must plunk down another $100 to $200 for the router then the savings will be minimal. I generally do all my woodworking with a drill, a pull saw, and a hand plane. I also have a jigsaw so i can cut a circle, and I have a circular swa, but I rarely use it.
I guess trimming up the inside of a cutout will be challenging, but how tight do the tolerances need to be?
What do you think, can this job be done without a router?
thanks!
mark
Old 7th December 2007, 03:07 PM   #2
cuibono is offline cuibono  United States
cuibono's Avatar
routers are very very handy. I got by without one for a while, but now consider it necessary. You could get by without one for a simple sub box, but having one makes it look much nicer - for instance, were you planning on mounting the driver flush on the box, or rabbeting it in?
A cheap knockoff from harborfreight.com would probably be perfect. I believe their tools have a pretty good warranty, actually.
http://search.harborfreight.com/cpis...uter&Submit=Go
Old 7th December 2007, 03:18 PM   #3
I was thinking that I could layer thinner (i.e. 1/4") MDF ontop of the 3/4" MDF to produce something like a rabbet. I have not looked up how deep the recess needs to be so I don't know how realistic this idea is.
Wow, those are cheep. The problem is I am somewhat of a quality fanatic. If I buy a tool, I like it to be a good one. I'd rather suffer through not having it than struggle with a sub par one. It doesn't have to be top of the line, but I do generally stay above Crapsman. I'm not saying harborfreight is bad because I don't know anything about them. I was looking at the Bosch trim router as a cheaper/smaller possibility, but then it wouldn't plunge, which I assume can be very useful. I certainly don't ever want to have to buy a second router.
-mark
Old 7th December 2007, 03:28 PM   #4
MaVo is offline MaVo  Germany
i think you can build boxes with just wood, saw, screws, lime, jigsaw. router will be good for making things pretty around the corners. i owned one, but since it died i build a few boxes without it. but no sonotube, so maybe i am wrong here.
Old 7th December 2007, 03:32 PM   #5
MJL21193's Avatar
Strictly speaking, you don't need a router to build speakers, as long as you are willing to improvise and/or spend a little more time.
Layering to achieve the recess for the driver is better than cutting it with a router IMO. It makes for a stronger baffle. For subs, a recess is for cosmetics only.
I have two routers - a large Bosch with a 1/2" collet and a small Makita trim router that has a 1/4" collet. I almost never use the large router for speaker building. The Makita does it all and was cheap ($70.00 on sale). You can buy a variety of bits to do most of the things you'll want to do.
Old 7th December 2007, 03:35 PM   #6
Default 1/4 vs 1/2
so if all I'm ever doing is edges, circles, and some slots would a 1/4" trim router do the job?
It would be nice to be able to get a plunge base for a trim router.
-m
Old 7th December 2007, 03:42 PM   #7
John L is offline John L  United States
John L's Avatar
If you are looking for a good cheap router, you can check out Sears for their sales. I haven't looked there for quite a while, but they always have routers on 1/2 price sale at one time or another.
Also, you can usually find a router on the cheap at a garage sale. But remember, it is in the bits and attachments that are expensive, and that is why Sears usually has their routers on sale.
If you think a router a bit too much, you should see we folks who have more than one. I currently have three: one mounted on my table saw extension(I use it as a router table); Craftsman 1 hp hand held; and a Craftsman 2hp plunge router. I could always use a fourth one. That way you won't have to change out bits all that much, and the bits, once set up are perfect, so why move them?
Oh, I am going to get a fourth one, a dedicated trim router.
Old 7th December 2007, 03:44 PM   #8
pinkmouse's Avatar
Since my Bosch broke down, I only have two, and I really miss the third...
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 7th December 2007, 03:47 PM   #9
When you say Sears do you mean Sears brand or just routers at sears? So how do you think the Sears routers compare to the Dewalt/Porter Cable/Mikita/Bosch routers?
I hate waiting, but if I can really get one for 1/2 prince that would be a pretty good deal.
Another reason for only have a limited number of tools is that I live in a 2 bed apartment with no garage.
thanks,
mark
Old 7th December 2007, 03:50 PM   #10
I have 2 drills, corded and cordless. I think I even have several saws, but I only use one ... actually 2.
CNC Router Dryseals Multi-Way 11 7th November 2006 03:01 PM
Need Router help xyrium Multi-Way 18 22nd July 2006 10:17 PM
New member with CNC Router pierre wessels Introductions 3 20th July 2006 03:44 PM
What to look for in a router? flaevor The Lounge 8 14th January 2006 05:35 PM
CNC router on ebay bigparsnip Swap Meet 3 22nd April 2004 04:39 PM
Page generated in 0.15175 seconds (73.03% PHP - 26.97% MySQL) with 11 queries
