Old 4th December 2007, 04:07 PM   #1
Default Adire 281 crossover schematic?
Hello all,
I bought a pair of Adire 281's a couple years ago and then had a couple kids so time has been a precious commodity At any rate, I'm in the process of building them now and have been able to find the cabinet plans, but not the crossover schematic. I remember reading on here a lot when I was considering the 281's and there were quite a few 281 builders at the time. I was hoping someone kept an electronic copy of the schematic????
Thanks in advance,
Russell
Old 4th December 2007, 05:27 PM   #2
I think I have a paper copy in the workshop. I always wanted to build a set of those and go figure. Their out of business now.
Old 4th December 2007, 05:27 PM   #3
Timn8ter's Avatar
I may have something archived. I'll take a look and let you know.
Old 4th December 2007, 08:51 PM   #4
Thanks all,
I actually just received a reply from Adire. I had sent them an email a few days ago and they sent the crossover schematic to me about an hour after I posted
I do have a question about it though. As I recall there was a tweeter polarity issue early on. The schematic shows the tweeter wired out of polarity (+ amp to - tweet). Does that seem right?
I'm going to try to attach the pdf.
Thanks,
Russell
Old 4th December 2007, 09:57 PM   #5
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
Yes, the polarity is correct. Wire your speakers as per the drawing.
The woofer has a 2nd order filter, and the tweeter has a 4th order filter. The 2nd order filter will have a 180 degree phase shift, and the 4th order will have a 360 degree phase shift. So the tweeter is wired backwards for phase alignment.
Old 5th December 2007, 10:49 AM   #6
I've no idea what 1.2R and 3.6uF is doing wired across the tweeter,
all I can say it is an extremely poor load at high frequencies and IMO
will lead to expiry (depending on its protection) of some amplifiers.
/sreten.
Old 5th December 2007, 02:18 PM   #7
DcibeL's Avatar
You mean the 1.3R and the 33.6uF? Looks like a Zobel to me, though I haven't done any simulations to see just how it affects impedance.
Old 5th December 2007, 03:04 PM   #8
Its C3 and 3.6uF I assume. 33.6uF capacitors do not exist
so it is a nonsense value and if taken literally would quickly
be terminal for most amplifiers. 1.3R is too low for a zobel.
/sreten.
Adire HE12 Crossover 95Honda Multi-Way 1 13th May 2009 05:59 AM
FS: Adire/Exodus Kit261 drivers & crossover Theli Swap Meet 0 18th June 2007 07:24 PM
*** Adire Tempest active crossover *** beatrix_choice Subwoofers 9 9th November 2006 09:04 PM
Active crossover Adire KIT281 drfrink24 Multi-Way 11 30th December 2004 10:45 PM
Anybody have crossover schematic? CryingDragon Solid State 11 20th September 2002 01:50 AM
Page generated in 0.10317 seconds (71.78% PHP - 28.22% MySQL) with 11 queries
