Old 4th December 2007, 10:22 AM   #1
Did it Himself
richie00boy's Avatar
Default 2 inch Peerless vs 2 inch HiVi Research
I have been thinking about using a small fullrange driver to run from around 300Hz upwards in a couple of different projects.
HiVi Research have two offerings both very similar:
http://www.swanspeaker.com/product/htm/view.asp?id=121
http://www.swanspeaker.com/product/htm/view.asp?id=120
The only real downside I can see to these is that Qts is very high.
Now Peerless are in on the game with their new driver:
http://www.madisound.com/catalog/pro...oducts_id=8267
Anybody used any of these three drivers and can pass comment? They all look very similar in performance from the graphs. Maybe I will just go with the A2S because it will cosmetically match the Jordan's on the front setup, and they are available in the UK easily.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 4th December 2007, 01:20 PM   #2
ashok's Avatar
From the specs the Tymphany driver looks like a better driver for an enclosure. Open Baffle might be better for the A2S but have you looked at the sensitivity ?
If I were you I'd pick the Tymphany .
Cheers.
AM
Old 4th December 2007, 01:31 PM   #3
Did it Himself
What leads you to that conclusion? The Qts value? I'm doing sealed chambers for the drivers.
Old 4th December 2007, 01:54 PM   #4
tinitus is offline tinitus  Europe
Honestly, I dont think any of them will be of much use at 300hz, you know, they should be able to play below the xo point
Old 4th December 2007, 02:30 PM   #5
Did it Himself
Resonance is about 150Hz so what's wrong with a 300Hz crossover point?
Old 4th December 2007, 02:49 PM   #6
ashok's Avatar
A sealed chamber will only raise the Q further . I wouldn't like that on the A2S. Open baffle might be OK.
I have just got some 4 inch drivers which I plan to use in an open baffle . The Qts is 1.47 !
If your bass driver is far away , 300Hz might be too high to crossover if you do not want imaging issues.
Cheers.
AM
Old 4th December 2007, 04:11 PM   #7
At very low SPL it may be ok
Old 4th December 2007, 05:11 PM   #8
Did it Himself
I take the point about raising resonance with the box. I could probably move the XO point up a bit without much detriment. The bass driver will be in the same cabinet. I wonder if I need to use instead the HiVi 3 inch driver...
Old 4th December 2007, 10:44 PM   #9
I wonder if aperiodic vents would be helpful?
~Brandon
DriverVault Soma Sonus Old Driver Tests
Old 5th December 2007, 03:49 AM   #10
planet10's Avatar
I wonder if I need to use ... 3 inch driver...
In his study of small drivers Zaph concluded that none of the drivers smaller than 3" were really worthy of consideration. http://www.zaphaudio.com/smalltest/
I recently fired up a set of the 3" Fostex FF85k (as per standard procedure around here, modified) on a test open baffle. Really quite excellent -- these could give a lot of more expensive tweeters a run for their money. I expect to get 100 Hz (althou at limited levels) out of them when i get them in a box.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
FS: Peerless 10-inch 831727 jmikes Swap Meet 0 12th March 2007 02:11 PM
Peerless 8 inch SLS - usable or not.... barackuda Multi-Way 6 17th November 2006 05:04 PM
8 - 8 inch Silver Flute and 8 TN28 HIVI jadenlinkletter Multi-Way 5 27th January 2005 03:58 AM
Passive Radiator system with 2x10 inch and 1x15 inch Lach O'Sullivan Multi-Way 3 13th September 2003 04:29 PM
Page generated in 0.15145 seconds (61.03% PHP - 38.97% MySQL) with 10 queries
