Hello,
I am currently planning my first DIY build and have selected a 6 1/2 in woofer to go with a 1" tweeter in a sealed box 2-way system. The woofer in question comes in either a 4ohm or 8ohm version and I am wondering what is the best practice when you consider the tweeter is 4 ohm. I have looked at the woofer specs and calculated some numbers and they definitely produce very different numbers when it comes to things like box volume etc. which I am prepared to work around if one of the woofers would better suit the tweeter. Should a 4ohm tweeter be matched with a 4ohm woofer or does it make little difference to use a 8ohm woofer and correct the impedance difference in the crossover? Thanks very much in advance! |
| MTM + woofer in a car | 901Fixer | Car Audio | 15 | 23rd September 2009 12:56 AM |
| What can I do with this woofer? | Bricolo | Multi-Way | 5 | 1st April 2004 10:37 PM |
| diy sub-woofer | takashi | Subwoofers | 3 | 19th August 2003 10:16 PM |
| the best mid-woofer? | joz | Multi-Way | 4 | 19th March 2003 09:19 AM |
| Qts of Push-pull woofer and Compound Woofer System... | haggy | Multi-Way | 1 | 13th December 2001 02:30 AM |
| Page generated in 0.06392 seconds (65.16% PHP - 34.84% MySQL) with 10 queries |
