Old 3rd December 2007, 10:32 AM   #11
"Wouldn't know about car gear: not interested and I ride as often as not. Silence in the car is wonderful. "
What I was saying was , You can choose to use car subwoofer driver for your home, cause, Most 12" car subwoofers are suitable for use in home. The prameters for car and home subwoofer drivers are similar. example Fs around 25hz, qtc between .3 to .45 (well, mostly) and Vas are also similar.
I have a 12" rockford fosgate punch sub. in my room , on a 2 cubic ft. box , ASAICR, The parameters of the sub are, FS 23hz, QTC .35 and Vas of around 2.5 cubic ft. It has a cast frame and a 3" VC and a big magnet for a 12 incher, it only cost me 140 usd. cause it was on sale, But so are plenty of 12" car subs are always on sale.
That sub is louder than my B&W 12" sub which I paid 1,300 usd.
BTW, they both sound good though, albeit, a little different sound quality.
Old 3rd December 2007, 11:58 AM   #12
vajolet is offline vajolet  Italy
thanks folks,
you confirm existing ideas. Project is a hifi-/cinema-application, no car !
Possible low-end-drivers:
ATC-SB75-314 sophisticated (old) brand, 75mm VC long travel, expensive
CIARE 12.00 SW 100mmVC, 11.5mm coil travel, price-value !
top-end:
2x audax PR170 ZO + 1x (XT1086+1030-1")18sound in d'Appolito
the audaxes feature a HDA-cone, analytic but loud, low distortion. There are louder ones, but not so "warm".
Rob
Old 3rd December 2007, 03:58 PM   #13
Brett's Avatar
Fair enough Marcel.
Vajolet: Ciare 12.00 SW is supposedly a good driver
PR170 in MTM, likewise excellent, but I would suggest the XT120 and the 1020, because of centre to centre distances in the MTM and the 1020 is the same as the 1030, but with a poly diaphram.
However, I'm not sure the Ciare will go low enough for a sub (Fs=43) nor high enough to meet the Audax clean. As an OTTOMH solution, perhaps the 12NMB420 in a sealed enclosure, and a dedicated sub for below 80Hz or so. More expensive, but you'd have an exceptional high efficiency full range system. Just suggesting....
Old 3rd December 2007, 06:33 PM   #14
hi Brett,
many thanks for comments !
Cone break-up of the 12" CIARE will occur 300hz above. Driver shows an ideal roll-off at ~230 hz, could be cross-frequency on the ashley-x-over, graph theoretical 18db down at ~400hz, where the audaxes (fs= 185hz) would be at home.
For bottom-end the curtain didn't fall finally. Centuries ago I built hybrid-systems for studiomonitoring and short-throw-PA, using the ATC12-SB-version + SM75-150 midrange-dome.
We tested a range of 12". Carefully manufactured types/cones you can use up to, let'say 500 hz without any cone break-up independant of cone-type, flat/stiff or concentrical design, but that's another story...
I already had a similar idea covering >100hz low end. You suggest 12" 18sound, it's o.k. My idea was using 4x "classical hif-units" 2x2-array (i.e. Vifa VIFA 17 WN 225/8 PAPER COATED or similar types) and the tweeter in center position. But this would extend width dimension up to >14", and cancel my favoured design of a acceptable slim column. Same way I have to live with the 11" of the xt 1086, not with your suggested xt 120 indeed.
Background: single audax generate usable 95db/m/w (only), specified 99db is typical cone-voodoo. Actually I don't know how it will sound crossing at 3-4k(-->x120) or crossing at 1.5k (1030/40 or BC ...).
My experiences are: the lower you cross to to compression the "harder" it will sound, but you'll have sophisticated dynamics.
In this case, my actual version will generate "hard" voices, don't know ???, must check. Smooth harmonic upper-mids we'll get crossing >3.5k not propably, surely. But where's the snare...haha..
In first version you'll favour the sound of your drum-set, 2nd the voice of Enrico Carreras.
By the way, the center-distances are another story, d'Appolito or not depends on this, but he will function better crossing at 1.6k, closing the circle again, no advantage without any disad...
Rock on Brett,
Rob
Old 3rd December 2007, 07:10 PM   #15
Brett's Avatar
Hey Rob,
Do a search for posts on the PR170, they're more often than not unhappy below 4/500Hz or so. With the XT120, I was thinking of a LR24 xover at 2k, which still wotks fine with this flare and gets the C-C for D'Appolito OK.
Anyhow, please post as your system progresses, as I'd be curious to hear how you go.
Cheers
FS: Large inductors, Large Ports, and Leaky Holes luvdunhill Swap Meet 10 6th March 2009 04:01 PM
Very large sized planar driver ( 180square feet) ...possible ? JinMTVT Multi-Way 33 13th November 2007 06:51 AM
advice on a set of medium sized computer speakers Dr. Photon Multi-Way 13 11th May 2005 06:14 PM
Medium-fi amplifier biasing Circlotron Solid State 1 24th July 2002 03:44 AM
Page generated in 0.10220 seconds (77.29% PHP - 22.71% MySQL) with 11 queries
