Open baffle horns? - Page 3 - diyAudio
Old 4th December 2007, 11:14 AM   #21
Banned
Originally posted by Tom Brennan
I've run JBL 2420s and Altec 288s sans the caps but hearing no big difference (if any) I put them back on. There was some discussion of this on the Lansing Heritage site, evidently some early WE compression drivers had no back cap but an open protective screen.
If you turn them around and use them without a horn you end up with a Super Dome, I have used/ measured a few drivers this way. The sensitivity goes down like 10 db but they really get linear, extended and open - to me they still sound like a dome though. - compressed and fake
Old 4th December 2007, 12:13 PM   #22
This has turned into quite an interesting thread, I'm enjoying the discussion. I know now that while horns can be mounted on an open baffle, if used by themselves they probably aren't capable of the sonic characteristics I was looking for.
I've also been corresponding with Darrel Hawthorne and he's been excellent explaining the whole dipole/bipole concept(not that I completely understand it yet ). I'm going to eventually build a set of OBs using his Silver Iris drivers.
BTW, anyone interested in a set of Mageplanar SMGa's? They sound lovely and have the soundstage I'm looking for but not the punch I want-
Thanks for the great discussion!
Old 4th December 2007, 09:31 PM   #23
rcavictim's Avatar
Originally posted by chops
Here's My Usher/Altec Horn Loaded Open Baffles...
There are probably counties where you`d have to bribe the planning commission by buying a building permit to build a set of speakers like that!
"There are more worlds than the one you can hold in your hand." Albert Hosteen, Navajo spiritual elder and code-breaker, X-Files TV Series.
Old 5th December 2007, 12:34 AM   #24
AJinFLA is offline AJinFLA  United States
Banned
Hi Tom,
What I was really asking was, were these part of an overall dipole design? An attempt to lessen the imbalance in the power response? Or basically just to see how it sounded in an existing design?
One of the issues that I looked at from my previous dipole/horn design was the power response shift between dipolar to directional monopole in the crossover region. Rear radiation from the tweeter helps to offset this, although there may be a penalty in the polar response. I need to do a ton of measuring with these yet (bottom pics)
http://www.diyaudio.com/forums/showthread.php?postid=1366614#post1366614
I will search the Lansing forum to see how they were being used.
cheers,
AJ
Old 5th December 2007, 12:50 AM   #25
ScottG is offline ScottG  United States
You can get that easily enough by integrating a sealed "subwoofer" with the panels.
(Note that it isn't really a subwoofer, more like an active bass "augmenter").
Most open baffle solutions don't have a lot of punch either (though yes, better than the maggies).
perspective is everything
Old 5th December 2007, 01:00 AM   #26
Well when I use them now I use them in conjunction with a Klipsch passive sub which balances out the sound nicely all off the way thru and gives the low end punch. What I'm missing is a little more "up front" sound and dynamic in the midrange- Thanks!
Lee
Old 5th December 2007, 01:47 AM   #27
Originally posted by AJinFLA
Hi Tom,
I was just screwing around to see how it would sound.
Old 5th December 2007, 03:51 AM   #28
chops is offline chops  United States
chops's Avatar
Most open baffle solutions don't have a lot of punch either.
Adding some EQ or building larger baffles can overcome that issue.
Charles
Old 5th December 2007, 09:42 AM   #29
My crude understanding is that there is a trade-off on efficiency and sound stage on the baffle design.The narrower the baffles, the better the sound stage but the response suffers some. Wider baffles in general provide more punch and response but narrow the sound stage somewhat. Is this off base?
Old 5th December 2007, 06:07 PM   #30
chops's Avatar
I'm not too sure really. My baffles are 24" wide and they image and soundstage like good bookshelf speakers.
Charles
Does open baffle suffer from baffle step? 454Casull Multi-Way 15 19th May 2012 03:12 PM
Open-baffle baffle length matejS Multi-Way 2 21st September 2010 04:49 PM
Murphy baffle radios [ open baffle ] keithpeter Full Range 10 11th September 2007 07:59 PM
what effect does baffle have on open-baffle system? kappa546 Multi-Way 6 24th January 2006 10:21 PM
Australians- what solid timbers for baffle? (open baffle loudspeaker) tktran Multi-Way 13 29th November 2004 11:09 PM
Copyright 1999-2017 diyAudio
