Open baffle horns?
Open baffle horns?
Old 5th December 2007, 11:57 PM   #31
MaVo is offline MaVo  Germany
i think the good image comes from the fact that they will have a narrow coverage pattern, so less waves hit the walls and generate phantom images of the speakers. since horns are directional and your big drivers are directional at higher frequencies due to beaming and directional at low frequencies due to the dipole calcellation, its a good setup for image.
Old 29th December 2012, 10:52 PM   #32
Chestnutt is offline Chestnutt  Romania
I was actualy thinking of a horn with no back chamber, goint to ~100hz-500hz
Smallish, yeh....HORNish. I think you lose some of the bottom octave without the chamber.
Any horn specialist around?
Old 29th December 2012, 11:09 PM   #33
POOH is offline POOH  United States
POOH's Avatar
I use an 80hz front horn with an 8" driver and no back chamber and I estimate the front wave to be up around 18-24db from the back when listening in front of the horn. The particular horn/driver combo sounds better without the back chambers I've used with them and there is little that the reactance annulling of the back chambers does to effect the bottom response of the horn.. A front horn that goes to 80hz with little ripple is not small. Mine are around 50" long.
Open baffle horns?Hide this!Advertise here!
Does open baffle suffer from baffle step? 454Casull Multi-Way 15 19th May 2012 04:12 PM
Open-baffle baffle length matejS Multi-Way 2 21st September 2010 05:49 PM
Murphy baffle radios [ open baffle ] keithpeter Full Range 10 11th September 2007 08:59 PM
what effect does baffle have on open-baffle system? kappa546 Multi-Way 6 24th January 2006 11:21 PM
Australians- what solid timbers for baffle? (open baffle loudspeaker) tktran Multi-Way 13 30th November 2004 12:09 AM
Copyright ©1999-2017 diyAudio
