Old 29th November 2007, 08:18 PM   #1
Default The "Poverello" three way project
Hallo,
I'm planning to build a three way loudspeaker with poor components.
Since italian names usually give an hi-end touch to a speaker:
-Opera, Bel Canto, Concerto, Puccini and so on...
I've decided to give an italian name to this project too:
"Poverello"
that means poor but in a nice way.
I found this 13 cm speaker that I would like to be the center of the loudspeakers, these are the characteristics:
60W
8Ohm
88db
Re 6Ohm
Fs 65Hz
Qms 2,65
Qes 0,52
Qts 0,43
MMS 6,5g
I think that a low mass will be usefull on voices and transients
Cms 0,9 mm/N
also this value seem ok
VAS 7,3 dmc
Bxl 5,5 Wb/m
Xmax 3mm
Le 0.55
http://www.ciare.com/pdf/catalogo/PM130.pdf
This is the frequency response.
In a 0,7 Qtc sealed box the woofer reach a -3db poin at 106hz. I know the Qts is a little low.
I think that this will be a nice way to naturally filter the low end and mix it up with a sub unit.
What do You think about this?
Please note that this unit cost just 20€ I think could be a nice place to start for a poor three way system.
Have You got any suggestion?
Old 29th November 2007, 08:47 PM   #2
That driver is peaky and I don't think it will sound very good.
If you really want to be 'poverello', perhaps you should go 2-way,
but use a better woofer.
Consider the HW132, it has a smoother response.
Old 29th November 2007, 09:23 PM   #3
what do You think about the MW 130 instead it has a smother response but it cost 35€ nearly doubled in cost
Old 29th November 2007, 09:37 PM   #4
I couldn't find a price list to compare prices,
MW130 looks OK as a mid driver, but my pick of the drivers is the HW203. Have a look at their projects HO3.21 and, for a 3 way, HO3.4
If you go 2-way, fewer xover parts mean you've got more money to spend on good speakers..... which is the key to a good sound in the first place....
"Proac 2.5 clone" or "Elsinore project" Joel Wesseling Multi-Way 10 26th May 2011 05:51 AM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Project 11.1 from Slone "High-Power Amplifier" Book Karl71 Solid State 46 6th October 2008 03:47 AM
My Line Array "bookshelf" project, help needed! Guijs Multi-Way 14 15th December 2005 08:34 PM
Suggestions on a preamplifier project with a "A/V processor loop" option Spyhunter Solid State 6 8th November 2001 09:31 AM
Page generated in 0.08297 seconds (73.96% PHP - 26.04% MySQL) with 10 queries
