Seems many here are looking for dipole woofers. I just across this and have not seen it mentioned here yet.
http://www.audiocircle.com/circles/i...?topic=47277.0 |
#2 |
Haven't seen those yet. They look like a smaller version of my Exodus 15's
#3 |
Am I missing something when he is talking about the low sensitivity?
If you have a baffle cutoff of 100Hz (32.5 inch baffle from the graph on the Single Driver Website), does the system not drop off at 6 db/octave down to Fs and then 12 db/octave below Fs? That would mean with a SPL rating of 81.7dB, it would be at 69.7dB at Fs. That 12dB is a lot of power to put into it to raise it back up to flat with the rest of the system and then still have to put a lot of power into it to get it to play loud. It looks like it may be an all right speaker but I think there are others in the same price range that may do better with less power. |
#4 | |
I'm not sure which graph you're speaking of, but I've seen some that are way, way off, as they take an overly simplistic approach that leave so many factors out, that they're basically useless at best and often are totally misleading. I have to say that I think that your example is too dependant on a graph and doesn't reflect the reality of dipole implementation. High sensitivity drivers usually have a higher FS, not as much x-max and none of them, AFAIK, have an XBL2 motor. It's all about compromises, but you need to evaluate which ones you're willing to live with. Best Regards, TerryO
"If you have to ask why, then you're probably on the right track." quote from Terry Olson's DIYaudio Forum application |
#5 |
The driver is designed to be used two or four in a baffle. We are doing a W baffle and the effective baffle width is much wider than on a flat baffle.
Keep an eye on my forum. I'll explain all the design details and show how they are to be used along with measurements and an explanation of the entire system. Just give me a couple weeks.
www.diycable.com |
#6 |
This is the graph I was referring to:
http://melhuish.org/audio/baffle.html Thanks for the clarification guys. I will watch this one and see what happens. |
#7 | |
frugal-phile(tm)
A better bet is to download Thorsten's baffle spreadsheet. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#8 |
Thanks Dave. I will look that one up.
#9 |
Yes...what Dave said. I don't know what other tools people are using but that graph is of little use.
Linkwitz has the best technical descriptions that I'm aware of. If you don't want to scratch all the hair off your head, just wait and give me a little time and I'll have some more details on how to use them.
www.diycable.com |
#10 |
Sounds good. I downloaded Thorstens spreadsheet and it looks good.
I have a hard time reading Linkwitz's website. I need things paired down to there most simplest state to understand them until I can continue on to learn the more detail, intrecit parts (if I ever learn them). |
| Dipole Ribbon tweeter isolation from dipole mid-woofer array | Bent | Planars & Exotics | 5 | 21st May 2009 12:10 PM |
| Dipole woofer how high | johnb | Subwoofers | 3 | 5th November 2005 10:11 AM |
| Newbie Dipole woofer help please... | santiu | Subwoofers | 5 | 30th October 2005 07:20 PM |
| Eminence LAB12 in a dipole woofer? | Hennie | Subwoofers | 3 | 8th January 2005 09:30 AM |
| Dipole Woofer Page | BAM | Multi-Way | 8 | 8th December 2003 10:49 AM |
| Page generated in 0.13822 seconds (76.70% PHP - 23.30% MySQL) with 10 queries |
