Old 29th November 2007, 07:05 PM   #1
sdclc126's Avatar
Default Sideways Dipole Bass
Does dipole bass need to face forward into the listening room in order to work, or does it not matter at the lower frequencies?
I'm purely concerned with aesthetics here actually, by making the woofers less visible from the front. I was thinking of taking an H-frame and turning it 90 degrees to the side so a finished panel would face forward, and then placing the mid/tweeter panel in the normal location above that.
For saving vertical space, could the H-frame be placed horizontally also? Perhaps a taller, line array type mid/tweet main panel could then go above the lower H-frame.
One more - picture a "tower" H-frame, with four+ woofers - turned sideways, could the now front-facing panel serve as a baffle for mid/tweet? I'm thinking the only way it could work is if the front panel is widened with "wings," extending out beyond the width of the H-frame. But then would the H-frame interfere with the dipole response of the mids?
Thanks.
Soft Dome
Old 29th November 2007, 07:26 PM   #2
theAnonymous1's Avatar
By turning the dipole sideways you are effectively in it's null where the front and back waves cancel each other.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 29th November 2007, 07:39 PM   #3
sdclc126's Avatar
I wasn't sure if this would apply to bass, it being less directional. I suppose there would still be a null though.
Soft Dome
Old 29th November 2007, 08:09 PM   #4
you can do that with a ripole
http://www.lautsprechershop.de/hifi/...i/ripol_en.htm
Old 29th November 2007, 08:23 PM   #5
sdclc126's Avatar
Yes I forgot about that - like the Linkwitz dipole woofer for the Phoenix. Can't do what I had in mind with an H-frame but can with dipole w/ woofers stacked and facing same direction.
I like that anyway - it saves a lot of space.
Soft Dome
Old 30th November 2007, 06:35 AM   #6
CLS is offline CLS  Taiwan
The null is very very obvious. I've tried that with my W baffle bass module.
Even in indoor, the dipole bass is very directional.
Old 30th November 2007, 07:04 AM   #7
This applies especially to bass. Its upwards in frequency where the dipole stops being a dipole(usually above a few hundred Hz).
You can use a variation of Ripole/W-baffle (I guess even a "half ripole" would do the job - I mean, only one driver mounted on the side of an U-Baffle)
I don't believe in audio believings.
Old 30th November 2007, 01:47 PM   #8
sdclc126's Avatar
Yes - I think one of the main design goals of dipole base is to BE directional, in order to mitigate room gain.
Soft Dome
Old 1st December 2007, 10:34 PM   #9
ttr is offline ttr  Finland
How about sideways woofer dipoles right beside front wall (maybe with a bit larger baffles than sketched there)? Walls are assumed to be thick concrete.
I don't have any excess wood to build some quick test baffles right now.
Old 2nd December 2007, 12:02 AM   #10
y8s is offline y8s  United States
y8s's Avatar
Send a message via AIM to y8s Send a message via MSN to y8s Send a message via Yahoo to y8s
you're still on the null axis. and a reflected null is still a null.
Dipole bass or Ripole Bass? MJL21193 Subwoofers 13 15th September 2008 07:42 AM
Active filter for bass dipole felixx Multi-Way 1 7th December 2006 12:05 PM
dipole stereo bass? xstephanx Subwoofers 63 1st June 2006 12:19 PM
Some dipole bass measurements John Sheerin Multi-Way 19 3rd January 2005 06:48 AM
dipole bass help amo Multi-Way 11 17th September 2003 06:06 AM
Page generated in 0.10113 seconds (79.51% PHP - 20.49% MySQL) with 10 queries
