i have tried this with delta 12lf. turning the dipole sideways had almost no effect on the bass. it was there, although without measurement i cant tell what was missing. they were toed in about 15 degrees. but the bass was there...
contradiction to theory i think
danny
danny
Gradient Helsinki are best at ~45 degrees toe-in! Not closer than 1m to side wall. The front wall and sidewalls are critical and symmetry is needed. I haven't heard them but some people like them and some don't.
http://www.gradient.fi/Gradient/Downloads_Helsinki_files/GRADIENT%20HELSINKI%20manual.pdf
Exactly in line with theory!... but the bass was there...
The dipole 8 radiation pattern holds true only for wavelength which are small compared to the room dimensions. If wavelength become larger (say >1m for "small rooms"), the dipole no longer shows its figure 8, but increasingly feeds the inidividual room modes only. The bass you will get at a certain position in the room will be the bass which the room modes produce there. That is the same procedure as for other bass loudspeakers, but with a somewhat different mode excitation.
With increasing toe-in (45° and larger) the dipoles tend to attenuate the lowest room modes parallel to a line connecting the bass drivers. That is a way to actively control some room modes which other radiation patterns don't provide.
Rudolf
Rudolf thanks. One can never learn enough 🙂
I suggest you build a test box and try it for yourself. Make some measurements to know if your missing something. OB is easy to build, should not take you longer then to cut a hole for the driver just to test it 🙂
And report back please when your done
Danny
Danny
In the Gradient example posted above by Melo ... I wonder if this sort of configuration works well because of the cardioid pattern of the mid driver. The front wall reflection isn't as intense as it would be with a front fired dipole sub and the limited front wall reflection of the mid driver doesn't work against the subs FR thru the cross over region as a result. The mid is primarily operating within the subs null region. Positive or negative effect/theory? Would this work as well as it does with a true dipole patterned mid?
Because mid and tweeter are cardioids, there should be an almost complete null to the back (frontside). The overlap of the bass dipole with the midrange cardioid will be tricky: Both drivers are in phase to one side and out of phase to the other side. This would become more of a problem if the mid had a true dipole pattern imho.The mid is primarily operating within the subs null region. Positive or negative effect/theory? Would this work as well as it does with a true dipole patterned mid?
- Sideways Dipole Bass
