Old 28th November 2007, 11:07 AM   #1
cph2000 is offline cph2000  Denmark
Default Bass in wall enclosure?
Hello,
Any idears on how to simulate the loading effects (i.e. freq. responce depending on driver and box size) of a shallow closed box hanging on a wall ?
I guess it would aproximate a closed box mounted in an infinite baffle ?
Help is much appreciated ..
Old 28th November 2007, 01:03 PM   #2
MaVo is offline MaVo  Germany
If the wavelength is big compared to the distance to the rear wall then there should be an addition with the sound that comes back from the wall, which should be a 3db boost if i am right. when the distance to the wall is 1/4 wavelength you get a cancelation notch because of the 180 degree phase shift. this notch will occur periodically at higher frequencies each time the reflected sound and the direct sound are of opposing phase (= comb filter). i dont know a program that takes everything into account. the directivity of the speaker should have a great influence on all this. perhaps you can make a simulation in akabak, but that will be a demanding adventure.
There will also be diffraction effects, which each box has to some degree. Additional to that, room modes and reflections will change the response.
this spreadsheet could be helpfull to see what the room does to the response:
http://www.pvconsultants.com/audio/reflection/rrc.htm
this one lets you simulate the diffraction:
http://www.tolvan.com/edge/
Old 28th November 2007, 08:31 PM   #3
Svante is offline Svante  Sweden
Svante's Avatar
Default Re: Bass in wall enclosure?
Originally posted by cph2000
Hello,
Just check the "Enable back wall" checkbox...
The result is far from an infinite baffle in most cases.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 28th November 2007, 08:49 PM   #4
Default Re: Re: Bass in wall enclosure?
I just downloaded the demo version of basta, is the "enable back wall" feature disabled from this version (I only get the "Baffel step / edge diffraction" frame in the box tab) ?
Old 29th November 2007, 10:50 PM   #5
Svante's Avatar
Default Re: Re: Re: Bass in wall enclosure?
Yes this feature is not free, but almost.
Bass enclosure for 3 way Dr.EM Multi-Way 65 28th April 2011 12:58 PM
using a wall of 15" woofers for bass. noviygera Subwoofers 2 25th August 2009 03:53 AM
Using solid wall as back of speaker enclosure? BL21DE3 Multi-Way 4 15th September 2008 10:41 PM
how far away from the enclosure wall should my port be? slicemaster101 Subwoofers 1 15th April 2002 09:35 AM
Page generated in 0.09584 seconds (75.08% PHP - 24.92% MySQL) with 10 queries
