I'm currently building a pair of very big 3-way speakers with the goal of good sound and high SPL. (If the sound is superb that's a plus, but I'm only going for good.) Oh, and cost. The cost is a huge factor; all the drivers, horns, and crossovers (I've already bought them) cost me less than $200.
The problem I'm having is that while the woofer and horn tweeter are efficient to about 93 dB, the mid-horn (hehe) is efficient to 110 db. (!!!!!) The mid-horn itself is 6.1 ohms DC resistance, and by my calculations, I need something like 5.97 ohms in series with that, in order to reduce the output to the level of the other drivers. Question 1: did I do that calculation right? Next question: how's the best way to attenuate this? Ideally I'd build my own active crossover and then triamp the thing (*droool*) but alas, I have not got the money to do such a thing... I'm thinking that if I go to my local art store and buy some BIG pieces of graphite, I can use them as series resistors next to the driver to cool off the sound some.... I mean really, it sounds terrible with the midrange so loud and the treble so wimpy.... Last question: anyone interested if I dig up a digital camera and take some pictures? |
#2 |
Normally you use an L-PAD. One resistor in serie and one in parallel. 10W resistor a normally enough. From my experience, it is hard to calculate the good value because of many factors. Simply buy a variable L-PAD and adjust to taste. When the sound is fine, read the resistor value on the LPAD and then build a fixed LPAD with standard resistor.
Imagination is more important than knowledge. knowledge is limited, imagination encircles the world. Albert Einstein FrankDIY's Audio Corner |
#3 |
Thanks...
I actually discovered that if I take a piece of foam left over from the project, and shape it to fit the throat of the horn, and then jam it in there, it gives about the attenuation I want. :-) I'm afraid I have neither the money nor the time to spend getting L-pads, and I suspect they wouldn't give the range I wanted anyway; it doesn't matter though, my problem is basically solved. I spent less than $130 on all the drivers for these boxes, and when you wrap it up to high SPLs, it really shows, especially to people who are spoiled like me. :-) The higs and mids sound like someone is going "WSHHHSHSHSHSH" out of the horns. It's very yucky. These are $5 ABS horns and I can tell by looking for 5 seconds, they are NOT shaped right. Oh well. It's for dance parties and I don't think they'll care a whole lot. Pictures? Pictures coming. Thanks again! |
#4 |
LPad are not so expensive. The 15W one are around 3-5$ and you need only one to "debug" you crossover
| attenuation using I/V | ailouros6 | Digital Source | 14 | 15th October 2008 06:20 PM |
| XLR to RCA with attenuation pad. | KOL69 | Everything Else | 1 | 24th April 2008 11:10 PM |
| hum attenuation | AndrewT | Power Supplies | 3 | 2nd July 2006 09:12 PM |
| Attenuation | argonrepublic | Analog Line Level | 5 | 23rd August 2005 07:22 AM |
| 10 dB attenuation box | june | Parts | 2 | 20th July 2004 04:07 AM |
| Page generated in 0.11680 seconds (58.57% PHP - 41.43% MySQL) with 10 queries |
