Old 25th November 2007, 01:27 AM   #1
JandG is offline JandG  United States
Default Focal 210cv1 8" coax for OB.....?
Has anyone tried this driver in open baffle..? It is 94db eff..& seems like it might be worth the risk for a open baffle experiment.
If it fails at least I got new car speakers.
Old 25th November 2007, 06:16 AM   #2
Off-axis response looks a bit smoother than most I've seen like it, although it's far from perfect, of course. Definitely needs to be listened to at 30-45 degrees off axis, and even then, there shows to be a slight 4-5 dB rise from around 15 or 16 KHz up. I'd probably expect to get down to 100Hz and below pretty easily, or maybe even as low as 60-80Hz or so usable output on a baffle of decent size, altho that last prediction is probably pushing it a bit. Don't expect anywhere near high output levels at those frequencies though without distortion setting in. I find the 94 dB sensitivity rating a little difficult to believe, even for a 2.83v rating, especially when it's rated 88.72 dB/watt/1m..which actually sounds about right.
Best Coax Choices (8" or 10") doug20 Multi-Way 6 21st August 2009 02:04 PM
10" Coax in OB inrank Multi-Way 27 12th September 2006 02:20 PM
Focal "W" cones as seen on JM Labs Utopia series KT Multi-Way 1 19th September 2005 12:52 AM
WTB: Focal & Audiom & Volts 11", 12", 13", 15" woofer gengis Swap Meet 0 17th March 2005 02:29 AM
Update on " THORS TACKHAMMER 5" coax THOR Multi-Way 17 11th July 2004 07:04 PM
Page generated in 0.06832 seconds (67.58% PHP - 32.42% MySQL) with 10 queries
