Old 24th November 2007, 11:43 AM   #1
Tenson is offline Tenson  United Kingdom
Default Data Sheet for Extremis 6.4
I bought a couple of 6.4's assuming the specs would b pretty much the same as the 6.8 but I just saw they are not all that similar. However I can't find a data sheet for the 6.4... can anybody help?
Old 24th November 2007, 12:00 PM   #2
I haven't been able to find it either. It actually appears as though there isn't one. I've even come across a couple of outdated product pages specifically for the 6.4 version, with a llink to the datasheet for it, and it downloaded the 6.8 datasheet. You might have already seen the following, and perhaps it's what caused you to post this thread, but I just came across this as well..
http://www.diymobileaudio.com/forum/...ead.php?t=8613
Old 24th November 2007, 12:14 PM   #3
Hi I didn't see that so thanks for posting it. I did find another thread about it on the same forum though... but not much use.
Having looked at the T/S specs I was planning to add a bit of extra mass to the 4 Ohm version since I have already built my box expecting the 6.8. The only think I really want is the impedance curve, I can measure everything else for myself.
Old 24th November 2007, 02:09 PM   #4
CSS/XBL is offline CSS/XBL  Canada
This is what I have:
Fs: 37 Hz
Qms: 3.3
Qes: 0.36
Qts: 0.31
Vas: 27 liters
Re: 3.5 Ohms
Le: 0.11 mH
BL: 6.7 N/A
Sd: 140 cm^2
Cms: 1 mm/N
Mms: 19 grams
Bob
Old 24th November 2007, 02:17 PM   #5
Hi Bob,
Am I right in thinking you have, or had some sort of connection with Adire?
It looks like I will have to email he address on their website and ask for an impedance curve for the 6.4.
Old 24th November 2007, 02:32 PM   #6
I was the Canadian distributor for Adire. Currently I am an XBL^2 licensee and have additional drivers in development; the SDX7 has just been released and the SDX10 and SDX12 are in process.
Please email me from my website if you want to take this offline.
Bob
looking for old data sheet unclejed613 Parts 3 13th May 2007 06:35 PM
HELP data sheet missing Benny the 2. Multi-Way 2 18th April 2005 09:48 AM
op amp/dac data sheet help Smiffy Parts 11 13th December 2004 08:14 PM
data sheet KCC Parts 5 6th January 2004 09:03 PM
Page generated in 0.09519 seconds (66.04% PHP - 33.96% MySQL) with 10 queries
