at what point is the magnet, top plate, t-yoke magnetized?
is the magnet charged first or is the enitire motor assemby put together first, then stuck inside the magnetizer to charge the magnet? what about the type of subs that use multiple little magnets surrounding the voice coil? same thing? thanx |
#2 |
There are many different ways. Really depends on the design.
Hear the real thing! |
#3 |
for the common overhung subwoofer with 3"coil and 50mm winding height using double stacked strontium magnets...just the usual industry standard...
but im also asking because i want to build my own subwoofer, i can get magnets both before being charged and after... but id really like to try building one using multiple magnets surrounding the coil...instead of the usual 'disc' magnets... i want to try this type because id have more freedom in design and could try more variations....but only if i wont have to get the top plate and t-yokes charged. if you look at the ddaudio 'z' series, the coil is practically even hung with the magnets, not the top plate....this type of design i think i can do. |
| Help required for using a FDD motor as a turntable motor. | binspaul | Analogue Source | 5 | 13th May 2009 03:59 AM |
| DIY TT: motor, motor PS, platter speed measurements | dice45 | Analogue Source | 52 | 9th May 2006 01:07 PM |
| De-magnetizing tape heads | Sir Trefor | Analogue Source | 13 | 20th June 2005 02:29 AM |
| Magnetizing Current in Push-Pull Converter | scottieman | Power Supplies | 3 | 28th January 2005 06:47 AM |
| MC Cartridge De-magnetizing software for PC soundcard? | KBK | Analogue Source | 71 | 9th November 2004 12:16 AM |
| Page generated in 0.06094 seconds (71.59% PHP - 28.41% MySQL) with 10 queries |
