hi
i want to built a 4 way Horn system. mid bass will be a fane studio8m in a 88cm diameter MDF tractrix horn 150hz - 1khz mid radian 950pb in a 49cm MDF diameter tractrix horn 1khz - 8khz tweeter jbl 2405 slot below 150hz i want to use 4 10" woofers on each side in a bass tower. any suggestions of woofer models ? the one i most like at the moment is a beyma 10LW30/N http://profesional.beyma.com/ENGLISH/producto.php Angelo my blog: http://www.flickr.com/photos/12312992@N07/page1/ |
#2 |
What exactly are you trying to achieve? LF (150 - what)? sealed or ported? max box volume? SPL?
#3 |
Fore such an impressive setup you need better bass than any 10" PA driver can manage ... at least 15"
But with an 4-6 driver array you could easily find a 10-12" hifi woofer http://www.madisound.com/catalog/pro...oducts_id=8304 http://www.partsexpress.com/pe/showd...number=296-430 |
#4 | |
Shelved the project as I look like I'll be in this smaller house for a few more years yet. |
#5 |
A single 15-18" woofer wont move that much ... its in the sub region below 50hz that you need multiple driver
#6 | |
I'd only do push-push now to get mechanical vibration cancellation, so at minimum a pair/side would be needed. |
#7 |
i don't want the bass tower to be too big. Acapella uses in their basstower also 10" drivers, sealed, probably Dynaudio.
Next choice i was thinking is the next bigger model, Beyma 12" LX60 in a sealed enclosure, 60l - 80l volume for each woofer. Since i pretend to drive them active with a plate amp, no subwoofer might be needed, since i can equalize the lowest frequencies. A idea would be also to use 2 Beymas in the bass region, above 40 hz, and use 2 subwoofers for the lowest bass. Any suggestion ? Angelo |
#8 |
Using a PA 12" like that in closed and then boost low frequencies will leave you with a dip/bump in low midbass ... when using a simple plate amp as EQ
So why dont you do like the Acapella you refer to, and what I suggested in the first place ... use good 10-12" HIFI woofers with appropriate sensitivity around 90db and nice low Fs ... 6 each side should do
#9 |
there is also a studio bass from beyma, which i heard good comments about it: the 12B100-R
http://www.toutlehautparleur.com/bey...00r-p-854.html http://www.fullrange-speakers.com/en...tsysteme/zarah might be better then the lx60 ? |
#10 |
Ah, so what you really want is a bass array - and likely a sealed driver bass array that works to 40 Hz in room without to much volume or excursion.
It looks cheap, but it isn't.. Try modeling this driver: http://www.eminence.com/guitar_speak...0&SUB_CAT_ID=5
perspective is everything |
| Bass horn driver? | Elbert | Multi-Way | 51 | 4th November 2008 11:59 AM |
| selecting a driver for a BIB bass horn? | brookbh | Subwoofers | 1 | 4th June 2008 03:15 AM |
| Driver selection to match bass horn | Lars Timm | Full Range | 0 | 31st January 2008 03:03 PM |
| Bass Horn project | Dioda | Subwoofers | 4 | 5th May 2006 04:48 PM |
| My Bass Horn Project (Input Welcomed:) ) | bigmike216 | Multi-Way | 18 | 26th July 2004 05:12 PM |
| Page generated in 0.11325 seconds (76.25% PHP - 23.75% MySQL) with 10 queries |
