I need some big help on wiring my speaker cab with a 3-way x-over.
Heres what it looks like: *2-8 ohm woofers *1-8 ohm midrange driver *1-8 ohm tweeter. _________________________ also thrown into the mix: *high range l-pad *mid range l-pad *Eminence pxb3-50 3-way x-over. _________________________ Any one want to be a big help to me and give me some help on wiring this? Possibly draw me a signal flow diagram? Any help would be much appreciated. Thank you so much. -Blake |
#2 |
As far as actually designing a crossover from scratch you will need to provide more information - such as the makes and models of the individual drivers, their frequency responses, T/S parameters, etc. Otherwise you're really just throwing darts in the dark.
The enclosure size will also need to be calculated for the mids and woofers. Are you going to build the enclosures or do you have some existing ones? Edit - I just re-read your post and I can't tell if you actually need crossovers or you already have them and need to know how to hook them up to everything - ?
Soft Dome |
| Crossover for vifa 2 way setup - how can I find out what this crossover is doing? | Tino | Multi-Way | 11 | 17th May 2009 04:21 AM |
| Help me with a crossover. | raypalmer | Multi-Way | 4 | 5th April 2009 01:48 AM |
| Passive crossover into active crossover | hahfran | Multi-Way | 16 | 10th February 2008 06:16 PM |
| Crossover help please :) | Tenson | Multi-Way | 17 | 15th April 2006 09:34 AM |
| Can you hear the crossover point of a speaker with a well-designed crossover? | 454Casull | Multi-Way | 11 | 2nd April 2004 05:48 AM |
| Page generated in 0.06854 seconds (69.91% PHP - 30.09% MySQL) with 10 queries |
