I have spent the last year with the Seas L18 in a .5 cu ft enclosure from Parts Express as depicted by John Krutke on his website. He later mentioned that if he had to do it again he would increase interior volume.
That said, what would your recommendations be for internal volume/tuning? I'm going to have custom floorstanding cabinets made, and I'd like to get it right. TIA, Neil
newbie! |
#2 |
I cannot see him saying that as 0.75 cuft is about the maximum you can get away with without overdamping bass too much, 14(0.5cuft) /16 litres is about right. In 21(0.75cuft) litres port tuning becomes quite critical and needs to be to the nearest Hz. /sreten.
#3 |
Thanks so much for the quick reply. Am I to understand (based on your uploaded response graphs) that 12.5 liters is a better call?
Which choice provides better power handling? Thanks so much!
newbie! |
#4 | |
No 12.5 litres is not a better call. Quote:
it is certainly not worth doing because 14L is "too small". Add a subwoofer...... /sreten.
#5 |
Hello,
I do recall making a statement like that. I wouldn't go so far as to say the .5 cu ft enclosure is too small, but I will say that the tuning frequency I used in that PE box was chosen by ear in my listening room, and is a compromise with enclosure size. I suspect if you went a little bigger you might be able to get a little more depth in-room at the expense of power handling. Don't rely too much on models, your ears are the best when it comes to selecting a tuning that works with your room. If you do want to have a better understanding of what tuning/enclosure really works in a design, you'd need a model that includes the series inductor, and an actual room response curve. I got my "room response curve" by having a speaker measured anechoic first then measured in room, then subtracting one from the other to see exactly my room is doing. I wouldn't expect people building my designs to do all that though, so experimenting is the key. .75 cu ft definitely is too large (I've tried it) but I think .65 cu ft would be about right. From there I'd recommend experimenting with the tuning in your room to see what sounds the best to you. Is it worth rebuilding? I'd say no, unless your goal is a different and/or better looking box design - in that case it's certainly worth it. Too bad PE boxes don't come in exotic burls or waterfall bubinga.
-Zaph|Audio- |
#6 |
Thanks to all for the input. I'm happy to see you weigh in as well John, thanks for that.
My reasons for rebuilding are twofold - I prefer the appearance of a floor stander. Just looks better to me. I would also like to have a separate crossover chamber, and perhaps some room for mass loading with sand. Considering that I'm using large air core inductors, big 600v caps and the impedance correction circuit, I'm sure I've stolen a bit of internal volume from spec. Perhaps I'll make the volume .55 and split the difference. I do not want to compromise power handling, so it sounds as though going much larger will not be a good idea. Kudos to all for the help...
newbie! |
#7 |
What about tuning with Seas P18 passive radiator??
#8 | |||
any box volume over the "classical" alignment is not "too small". As you say it is best to understand all that is going on rather than blindly following a simulation tool. Quote:
below port tuning so low tuning is good, but then you do not get the extra power handling further up in frequency with the higher port tunings. In this particular case there is not a great range of freedom. I'd follow Zaph's suggestion of what is about right 0.65cuft/ 18litres which is the lilac curve already shown, there with a port tuning of 36 Hz. For perspective 41Hz is the bottom E of an electric bass. Generally speaking a box vented to 41Hz will struggle with the lower B / 31Hz of a 5 string bass / bottom end of a keyboard / piano and in a lot of cases not capture kick drum fundamantals. For this case the of sensible tunings is narrow, but I will note that by definition the lower port tunings have superior transient response. The thing to avoid IMO is an obvious "knee" in the response. IMO ~ 36Hz is about right for a nominal 18L box. But some prefer the "more" bass of higher tunings, especially on sustained bass notes with less transient character. Note that the -6dB point slowly extends with the lower tunings but not by much, its the response above that should match to the room which you expect to have bass gain, therefore the flattest response is not what is best, ideally droop and gain match. Quote:
and high output, i.e. the required port is too large for the box. In the case the required port is not particularly large, and minimising box volume not a concern (can be increased to accommodate a large airflow port) there is little benefit in using a passive radiator. /sreten.
#9 | |
-Zaph|Audio- |
#10 |
I suppose I should finally add that if you routinely like driving speakers to there limits then in terms of power handling in the bass there is no substitute to a subsonic filter. For an 18L box tuned to 36Hz maximum power dips to a minimum ~ 50W at 55Hz. Below port tuning it is ~ : 50W at 31Hz, 25W at 29Hz, 12.5W at 25Hz, 6W at 20Hz, 3W at 10Hz. The exact actual numbers do not matter much, its the principle that counts. /sreten.
| Bass Effeciency, Driver, Tuning, etc. | CLS | Multi-Way | 0 | 6th November 2008 08:26 AM |
| 1x10" bass guitar monitor with variable port tuning and notch filter? | alexclaber | Multi-Way | 7 | 1st April 2008 06:24 PM |
| Tuning bass reflex port | beamnet | Multi-Way | 0 | 28th September 2005 01:03 PM |
| Bass Reflex Enclosure & Port Tuning | D_GR8_1 | Multi-Way | 2 | 2nd December 2004 09:11 PM |
| Dipole bass with Seas L26 alu woofer? | cyclo | Subwoofers | 16 | 4th September 2004 02:05 PM |
| Page generated in 0.16682 seconds (69.93% PHP - 30.07% MySQL) with 11 queries |
