Seas ER15RLY and Peerless HDS Nomex (830873) are both very good midwoofers and measures well. http://www.zaphaudio.com/5.5test/
(Thank you Zaph for your fantastic page!!!!) But which one do you prefere?? I want to use one of them in a 2,5 way with active 4th order LR at ~3000k. Tweeter will probably be Vifa XT19 or maybe Seas 19TFF1. |
#2 |
On paper the Peerless is more suitable for a 2.5 way due to its response. /sreten.
#3 |
Are you sure you dont mean the Seas ?
#4 |
No. I meant the Peerless. A 0.5 way has 6dB of BSC by default. Work out the rest yourself .......
/ sreten.
#5 |
Thanks for the responce, right now it´s 50/50!
Since I'm going to use a an active filter I can adjust the LF responce if I want but I think the extra bass from the "0.5" will be enough (as sreten also wrote) Since I haven't heard any of them I would be very happy to get some comments from someone who has! |
#6 | |
#7 |
Not exactly what you asked but to me the graphs look better on the Peerless. A little less distortion and flatter response graph then the SEAS.
#8 | |
I agree about the distortion and FR....but how about the CSD? And does thease measurements tell us all about the sound?? |
#9 |
Ok, not to start a flaming war in here but according to some, CSD doesn't show anything more then the THD and FR graphs already do. Just a different way of looking at the same data. I stopped looking at them completely but that is just me. It's also been said that once your x-over is installed, it will make both CSD graphs look similar, so I pay more attention to THD.
What I would be curious about is the difference in X-max. Granted in a MTM speaker x-max is less of an issue because you have double the woofers but 3.5mm to 5.0mmm is a big difference. Can anyone comment on that? |
#10 |
Just to add to the war
THD and FR tells you little about the transient responce. Maybe if you add the phase responce that will be enough........The difference in X-max is interesting....but peerless has lower LF THD at the level Zaph measured. Also, is larger X-max always good or does it effect the midrange? (http://www.zaphaudio.com/lowxmax.html) |
| Peerless HDS Nomex | bjackson | Multi-Way | 1 | 7th February 2006 02:26 AM |
| Peerless 830873 + Vifa XT | Tomac | Multi-Way | 1 | 11th December 2005 02:43 PM |
| Bass/mid drivers - Peerless or SEAS? Nomex? | Jorge | Multi-Way | 8 | 19th November 2005 09:44 AM |
| Peerless 830875 Nomex????? | Gavinator68 | Multi-Way | 2 | 8th November 2005 01:55 AM |
| Page generated in 0.10250 seconds (80.92% PHP - 19.08% MySQL) with 10 queries |
