Old 19th November 2007, 10:09 PM   #31
ryoung is offline ryoung  United States
Right now I'm not set on 2-way 3-way or 4-way.
My goals for this project are to have a good set of speakers for music as well as home theater without the need for an additional subwoofer
Old 19th November 2007, 10:55 PM   #32
What's the deal with the sloped back and the... I don't even know what the proper words are. The cut where the width of the cabinets decrease - why?
Old 19th November 2007, 10:58 PM   #33
Cosmetic
Old 19th November 2007, 11:58 PM   #34
If you need to minimize the width of the cabinet (not necessary unless for WAF, IMO), I would suggest a 3.5/4-way in the way of TMWW or TMWWS (S for side-firing sub).
I'm thinking Seas 27TBFCG crossed to a Dayton RS52AN-8 crossed to two Dayton DA175-8 (or better, depending on budget). Also, if you watch a lot of movies, you'll probably want a sub in there.
Crossing around 2kHz and 800Hz will keep off-axis response fairly flat and avoid trouble zones wrt harmonic distortion, I should think.
Old 20th November 2007, 12:32 AM   #35
tinitus is online now tinitus  Europe
3.5 way makes no sense
And really, whats the point of making 1.class enclosures and then mount sub drivers in them to really excite some profound ressonance
Old 20th November 2007, 12:46 AM   #36
So would I be better making the enclosure wider and using a forward firing subwoofer?
Old 20th November 2007, 01:10 AM   #37
You will probably get the best result with a "standard" 3way and a Linkwitz Gainer on the woofers ... but it really depends on your goal and whether you can design and measure a crossover
But its trouble getting regular woofers with enough Xmax ... maybe you will have more luck with a 2.5way with sub
Old 20th November 2007, 02:06 AM   #38
Zaph has a small and cheap MTM which you may be able to use in your own design with side subs
It may be a good idea to make your design modular
Old 20th November 2007, 02:27 AM   #39
MJL21193's Avatar
I liked what you had back in post #5. Simple, good looking.
If you take much more advice here, you'll end up with the same-old same-old that there's a billion of here - the boring rectangular MTM.
My suggestion is to stay with it three-way with the midrange and tweeter in the top unit. Then as mentioned before, use two shallow woofers push-push near the bottom of the bass unit. fire your port out the back.
Old 20th November 2007, 02:42 AM   #40
What are you building your models in?
Please critique my PCB design darkfenriz Class D 26 8th August 2008 03:49 PM
$2 speaker, $10 crossover (Can somebody critique my design?) Jim85IROC Multi-Way 9 10th March 2004 05:03 PM
Critique my USB DAC design MWP Digital Source 14 14th August 2003 07:00 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
