diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   Extended range measurement mics and pre-amps (http://www.diyaudio.com/forums/multi-way/112046-extended-range-measurement-mics-pre-amps.html)
percy 17th November 2007 12:07 AM
I am looking for suggestions for measurement microphones that could measure well into the 40-50Khz range, and pre-amps to go with.
Any diy projects out there for that purpose ?
TiA!
Thunau 17th November 2007 01:55 AM
A preamp that has 50k bandwidth is not that hard to find, good luck finding a microphone capsule to go with it though.
Basically your choices are a M50 from Earthworks, DPA (formerly B&K) 4004 or a Sanken CO100k- all of them cost between $1500.00 and $2000.00.
I own an Earthworks M30, which costs 1/3 of the others and don't miss the extra ultrasonics when working with loudspeakers and systems.
A Behringer is good to about 16k, then it starts rolling off. Most capsules you'll find for DIY will be comparable. Otherwise Behringer and other Chinese based manufacturers would be selling $100.00 measurement mics that go to 50k.
Why do you need a 50k mic?
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
