Parallel inductors (dumb question) w/ Zobel followup
Old 16th November 2007, 09:31 PM   #1
arc2v is offline arc2v  United States
Default Parallel inductors (dumb question) w/ Zobel followup
Maybe this is because it's friday at 4:30 and my brain is fried, but I have a parallel inductor question.
I'm familiar with the L=L1*L2/(L1+L2) math for parallel inductors and resistors.
My question is is the DCR in this arrangement the same? DCR=R1*R2/(R1+R2)?
The reason I ask is for Zobel network calculations.
I have drivers in parallel with 1mH inductance and 6.4Ohm DCR.
Should I use separate Zobels for each driver, or one at the end of the crossover, calculated for the drivers in parallel?
I think it's simple and the answer is: design a zobel for 0.5 mH and 3.2 Ohms, but my brain keeps second-guessing.
Thanks in advance, and I did search, but didn't come up with anything on this topic.
Old 17th November 2007, 12:47 AM   #2
Curmudgeon is offline Curmudgeon  United States
If I understand, you simply have the two drivers in parallel. Two woofers or mids? In that case one Zobel; but a larger problem I have is why an LR Zobel? A Zobel is a series RC across the driver terminals, to prevent a rise in high frequency impedance caused by the drivers' inductance.
A conjugate is an LRC network, designed to maintain a relatively flat impedance through the LF resonance region.
I just awoke from a nap... am I muzzy-headed still?
There are a lot of sources for this sort of information, I tend to be partial to the Vance Dickason Cookbook.
Old 17th November 2007, 01:41 AM   #3
No the LR is the woofer, modeled as an inductor and a resistance (as they are usually put into the calculators).
I was planning on a traditional R-C parallel circuit (R and C in series, parallel to the woofer pair).
Old 17th November 2007, 05:50 AM   #4
jnb is offline jnb  Australia
There isn't any compelling reason to use more than one RC (at least in my opinion). You are correct about halving the driver impedance for two in parallel. Just calculate the RC for a single driver and halve the resistance and inductance.
Old 17th November 2007, 09:39 AM   #5
Svante is offline Svante  Sweden
Svante's Avatar
...you mean halve the resistance and double the capacitance ?
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 17th November 2007, 10:39 AM   #6
Yes, thank you Svante. Guess I'm having one of those days
Old 17th November 2007, 12:41 PM   #7
Got it. Thanks all.
I knew I was overthinking it.
Old 18th November 2007, 03:21 AM   #8
Thanks, I feel better now .
Old 19th November 2007, 02:00 PM   #9
Okay, I did the calculations and the capacitor it wants to use, is, well, huge!
What do you all use for your Zobels? 'lytics? Or do you enjoy spending $30 on a capacitor that isn't in the signal path ?
I built the crossover without the Zobels (woof and mid) and so far it sounds great. I know I still need it, though, due to some nasty breakups that occur about 3 octaves above the woofer X frequency and then a really loud ring in the upper octaves. I'm hoping the zobel will help the normal crossover damp those out without needing a special notch filter or higher slope.
Thanks again for the help, all!
I'll be posting measurements and pics this week of the prototype.
Old 19th November 2007, 03:33 PM   #10
auplater is offline auplater  United States
auplater's Avatar
Default Big caps
When I was building my main dipoles, I listened to just the woofer section (d/c the mid/tweeter part of the xover) to determine what effect the zobel had... then subbed different values until the "voicing" was correct; the calculated value was pretty close.
You might consider motor start caps for this, larger values are pretty cheap compared to poly's/ other types... I've heard no ill effects, but, as always... ymmv.
What value of cap did you come up with... what frequency does the impedance of the woofers double?
John L.
"I've forgotten more than I care to remember" The Last Conspirators
Parallel inductors (dumb question) w/ Zobel followupHide this!Advertise here!
Inductors in series/parallel? QED047 Class D 6 11th August 2009 04:10 PM
Parallel Inductors in PSU monarodan Pass Labs 22 2nd January 2007 03:19 AM
Dumb parallel question Cloth Ears Multi-Way 6 13th January 2006 06:59 AM
Does the DCR of parallel inductors matter? Mos Fetish Multi-Way 4 3rd February 2004 11:43 AM
pi filter in class a amp: okay to parallel inductors? jwb Solid State 6 20th October 2002 08:56 PM
