Old 14th November 2007, 03:49 AM   #1
Default PC board question: Dayton BR1 Kit...help please
Ok this is not my first time building a speaker kit, but I have a completely noob question.
I am in the process of building crossovers, and I cannot figure out whether or not the leads of each component need to actually be attached to another lead by soldering, or if I should just solder them in place where they go into the board.
http://www.partsexpress.com/pdf/300-640.pdf
This is the link for the owners manual of the kit, where it supposedly explains it. There is a picture on page 12 showing the bottom side of a completed crossover. The leads do NOT seem to be soldered together, instead each lead seems soldered in place on its spot on the PC board and then the excess wire is just cut. That is what I see anyways.
Then, it tells me to solder the "rivets" but I do not see what to solder them to? It seems like the picture shows him just soldering in the holes? I dont see what this accomplishes.
I can read schematics and instead of writing this whole post, I could just wire the thing onto a piece of cardboard. However, I am really very curious how this little board works. Any insight would be appreciated.
Thanks,
JG
Old 14th November 2007, 06:19 PM   #2
Components are not hard wired. Soldered to PCB and glued to board.
soldering the terminals gives a better connection between the
copper of the PCB and the rivets, and prevents corrosion here.
/sreten.
Old 14th November 2007, 10:49 PM   #3
That clears up so much. And I guess it makes sense. I just did not see any pattern that proved to me there was some sort of internal connections made between all of the copper spots. But it must be all internal.
Thanks,
JG
Dayton RSS390HF sub project question.... jjkozlow Subwoofers 17 22nd June 2007 01:40 AM
PE dayton 2-way Xover NOOB Question dyonge Multi-Way 11 28th December 2006 09:21 AM
Dayton BR-1 Crossover Question. RDV Multi-Way 2 6th June 2006 09:55 PM
Dayton 295-130 Sub Question? crippledchicken Subwoofers 14 23rd October 2004 11:28 PM
Drawning board: Dayton Aluminum and Tangband 28-847SA Hybrid fourdoor Multi-Way 8 27th June 2004 05:22 AM
Page generated in 0.08515 seconds (66.70% PHP - 33.30% MySQL) with 10 queries
