diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   Amp for active loudspeakers (http://www.diyaudio.com/forums/multi-way/111882-amp-active-loudspeakers.html)
Nm2285 13th November 2007 08:10 PM
I want to make some active speakers to use as basically near-field monitors (for my computer). I've been searching for plate amplifiers that can fit in the speakers themselves, but to no avail. The only thing I see is subwoofer amps. Anybody know where these can be found?
Jonathan Bright 13th November 2007 08:19 PM
Hi Nm2285, just curious, what is a "plate amplifier" I'm not familar with the term.
CSS/XBL 13th November 2007 08:20 PM
The Solen AP series is available if your interested.
http://www.solen.ca/v1/
Bob
chrisb 13th November 2007 08:30 PM
While there are some interesting sub/sat monitor amp combinations or even full range plate amps available, most are physically larger than anything qualifying as "mini-monitor" could accommodate.
For example, the Solen AV series that Bob referenced above would require a minimum enclosure back panel size of 5 1/2" x 9", plus additional depth of cabinet to allow clearance for power supply components. (approx 3 1/2" IIRC)
In addition, most are more power than you'd probably need for a computer monitor speaker. This sounds to me like the perfect candidate for something like:
http://www.audiomagus.com/component/...art/Itemid,27/
or any basic T-amp
If you really need to "self-power" your speakers, you could always just build one of these little guys, or something like the 41HZ series of kits into (one of) the enclosures.
CSS/XBL 13th November 2007 08:43 PM
There is also a less powerful version available from MCM.
Bob
Resources saved on this page: MySQL 18.75%
