Old 13th November 2007, 09:53 AM   #1
cs is offline cs  United Kingdom
Default Woofer recommendation
I am looking for an 8" woofer with fs at around 20Hz, and Qts in the range 0.3 to 0.4. Can anyone recommend a suitable unit ?
Most of the woofers I have seen have higher fs, or lower Qts.
Old 13th November 2007, 11:23 AM   #2
SCAN-SPEAK 21W/8555-00 8" Paper cone
http://www.madisound.com/catalog/pro...roducts_id=947
Not sure what your needs are, what you're using it for, budget, etc etc...
but as far as strictly searching for the criteria you listed above, that's probably about as close as you're going to get.
Old 13th November 2007, 10:48 PM   #3
Hope the links work
http://www.partsexpress.com/pe/showd...number=295-456
http://www.partsexpress.com/pe/showd...number=295-480
http://www.madisound.com/catalog/pro...05cd8d873a79e0
That is why they make vainilla and chocolate!!
Amp recommendation and help dxdenis02 Car Audio 2 5th August 2008 09:37 PM
Dipole Woofer for upper bass Recommendation Hara Multi-Way 5 11th June 2007 07:39 PM
8" Woofer Recommendation (UK) bluetomgold Multi-Way 5 20th December 2005 10:11 AM
Woofer recommendation mbrennwa Multi-Way 0 27th March 2005 11:13 AM
Qts of Push-pull woofer and Compound Woofer System... haggy Multi-Way 1 13th December 2001 01:30 AM
Page generated in 0.07710 seconds (64.61% PHP - 35.39% MySQL) with 10 queries
