Old 12th November 2007, 01:29 PM   #1
Default Dynaudio vs. PHL: Which 12'' would you use?
I am wondering, whether I should rather mate my Dynaudio D76AF with a:
A: second hand Dynaudio 30W-54
B: PHL B30 4021
C: a second hand Dynaudio 30W-100
Xover Point will be around 450-500, 24 dB, active. The 12'' will be equalized to roughly -3dB 30Hz in a CC.
Besides the fact, that the Dynaudio is somewhat cheaper in the beginning and of course is "retro" and would be perfectly "in style" with the Dynaudio mid, moneywise both are going to be equally expensive, as soon as one exchanges the pair of used Dynaudios for new ones (due to whatever). Refoaming is also a problem. I therefore suppose, a new PHL will be the better investment (btw.: K+H are supposed to use it in the o500c, xover at 520 Hz).
Based on measurements I came across, harmonic distortion should be rather equal with A and B, C may be better, the PHL might have a little advantage in k2 and the Dynaudio 30w54 with k3. The PHL has 140 sqcm more Sd (400 vs. 539); beaming should start at 460 Hz (Dynaudio) vs 400 Hz respectively.
The 30W-100 is a little off in my ranking, since it needs a huge volume according to published parameters. The 30W-100XL would be an option, yet hard to find.
So, would you rather take A, B or C?
Thanks and regards,
Leif
I try dynaudio d af 28 marcoc7245 Multi-Way 2 8th April 2008 07:40 AM
Dynaudio help ! zeonrider Multi-Way 8 1st February 2008 05:45 PM
Dynaudio D54's, Anyone know anything about these? speedemon Multi-Way 3 21st February 2007 12:55 PM
Dynaudio D-52 Jere Multi-Way 37 8th October 2004 12:57 AM
Dynaudio Roy Lewis Multi-Way 0 12th February 2004 11:21 AM
Page generated in 0.05807 seconds (73.78% PHP - 26.22% MySQL) with 10 queries
