Hello all,
I'm designing a speaker driver for one of my engineering classes, and I had a few quick questions I was wondering if anyone had any thoughts on. Quick introduction to the project, it gives us all a few basic parts, el cheapo magnets, wire of most any gauge of wire, and some bolts. We can buy additional things, with a rather small budget. So the only thing I was going to buy was a nice Neodymium ring magnet (the ones they give us have a TINY hole, 1/4" or so, too small for any conceivable voice coil that I can build, and it seems inefficient to stack them outside the coil. The magnet I was thinking of was 1.5" diameter x 3/4" thick, 0.760" hole. That way I can just put a standard .5" steel rod as the center pole (aka 1st diagram on http://www.consult-g2.com/papers/paper8/paper.html). I was thinking that since there’s a stronger field with the neodymium the voice coil would have a larger force on it, and therefore get more sound with the same current. Is this correct, or is there some reason that this is inaccurate? Also, I was wondering what a good diameter for the cone would be. I designed a basket for the front/rear plate with a 5” cone in mind. I was thinking “treated paper” for the cone would be pretty easy, though I’m not sure what they treat it with; cyanoacrylate (superglue) makes paper pretty stiff, though it might also make it kind of heavy. Or also, I was thinking I could get a stiff piece of polypropylene from a folder or something, and heat it with a heat gun, and trying to shape it over a mold. This seems hard though ![]() Thanks for your suggestions! Mike |
#2 | |
frugal-phile(tm)
http://t-linespeakers.org/design/tweeks.html And consider EnABLing them dave PS: you are not allowed to savage a dead driver for parts?
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
Stick with paper.
conical holds it's shape well, but does ring in bell mode. The surround might help suppress this. Keep it light, very light. minimise any treatment, just gluing the parts together will add significant weight. Tinsel leadouts will suffer fatigue if the cone movement allows them to bend at the junctions. Try to get them shaped so that they flex along most of their length.
regards Andrew T. |
#4 |
Hey,
That mod podge looks like some interesting stuff, I'll order some and see what happens. Heh we're not allowed to use any parts from existing speakers, that would make things too easy :-P Any ideas about the stong neodyimum ring magnet vs an array of crappy small ring magnets? Thanks guys! Mike |
#5 |
Make the 5" with NO SURROUND and it will work as a tweeter
#6 |
Hey,
For the surround I was planning on using thin craft foam, I ordered some 1mm thick stuff, it was really cheap so I'm not that commited to using it. I was thinking of using it for the spider as well, in a circle with flaps cut out, although thinking about it again I realize that the bottom of my magnet is going to be closed off by a steel plate with a .5" bolt in the center. I guess I could cut some holes around the bolt and stick toothpicks or something through. Or I could make the voice coil bobbin longer and have the suspension thing on top of the magnet. Man I don't know how the spider works in commercial speakers, it seems like the most difficult part (a very light spring in a tight space that has to maintain the V.C. in the tiny gap between the center pole and maget. All while oscillating.) Mike |
#7 |
You should make the back spider out of threads
First you align the voice coil former in the gap with paper strips from the front, before mounting the dustcap Then arrange the spider threads so they just touch the voice coil former ... they should tightened equally At the point where the threads touch the voice coil former you glue them with "fast glue" You can have 4, 6 or 8 threads ... with this size driver 4 threads should be sufficient Dustcap can be made from a table tennis ball ... but maybe too heavy fore this driver A little reading http://www.duelundaudio.com/download.../HJEM3.WPS.pdf from side 15 http://www.duelundaudio.com/Articles...en_Duelund.asp |
#8 |
Hey,
Wow that thread idea is fantastic, way better then the dumb kludge I was planning on, thanks. I think I know pretty well how I'm gonna build this thing now, though I'm still not sure if there are any issues with the really strong magnet I'm planning on. Thanks for the advice! Mike |
#9 | |
Depending on the type of speaker you are making, you may wish to download the driver design spreadsheet I threw together. You need to supply the gap flux, which requires a program like FEMM. link: Diy dynamic driver
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#10 |
The dust cap could be the end cut off a hard boiled egg with a sub-miniature rotary cutter.
Cheers ......... Graham. |
| designing horn for compression driver & tweeters | jayam000 | Multi-Way | 0 | 15th April 2009 09:26 AM |
| Designing my first 2-way speaker | Twisted85 | Multi-Way | 27 | 13th December 2006 02:07 PM |
| Help designing an efficient HT speaker | paulspencer | Multi-Way | 5 | 4th April 2006 01:20 PM |
| Designing a notch filter for the TB W4-1320 Bamboo driver... | fjhuerta | Full Range | 8 | 26th November 2005 03:19 AM |
| Page generated in 0.10956 seconds (89.56% PHP - 10.44% MySQL) with 10 queries |
