Old 12th November 2007, 02:25 AM   #1
Default how to understand driver specs?
can some one please explain how to read, and understand driver specs for midrange (woofers), bass (subwoofers), and tweeters please?
Old 12th November 2007, 02:40 AM   #2
http://www.eminence.com/resources_data.asp
Old 12th November 2007, 06:41 AM   #3
thank you ever so much.
just one more question, would u want a tweeter with a higher Fs or a lower one?
Old 12th November 2007, 06:41 AM   #4
also, do you know any other links that provide with more info?
Old 12th November 2007, 07:48 AM   #5
Depends on everything else regarding the design. Generally, you'd want a tweeter with a lower Fs to have the ability to cross lower to a mid/woofer (very typical with 2-way designs). The opposite is true for crossing higher, although it doesn't really hurt anything to have a lower Fs if crossing higher...just that the tweeter's resonant freqency shouldn't be a big factor of your buying decision in these circumstances.
What kind of info are you looking for exactly? What specs do you not understand? Just Thiele-Small parameters? Graphs of some sort?
In any case, www.google.com should be a good starting point.
choosing specs for driver that will be used for OB c3conv Multi-Way 3 21st November 2008 07:28 AM
help with driver specs threegee Subwoofers 19 24th April 2006 05:39 AM
EAW 18" driver specs Graydon Subwoofers 26 7th November 2004 02:43 PM
Any specs on this JBL driver? Bull Car Audio 4 19th September 2003 08:21 PM
Need Dynaudio driver specs fishball79 Multi-Way 7 25th February 2002 09:45 PM
Page generated in 0.06440 seconds (81.92% PHP - 18.08% MySQL) with 10 queries
