I am thinking of using Fostex FE108E¢² 4" FULL RANGE Sigma Series but crossing it at about 1000 Hz. It is rated at 1W / 1m 90 dB. Nom. Power 24 Watts
What would the power rating be at that point? Znom 8 ohm Re 6.8 ohm Le@1kHz .038 mH fs 77 Hz Qms 7.79 Qes 0.32 Qts 0.3 Mms 2.7 g Cms 1.59 mm/N Sd 0.005 m2 BL 5.2 N/A Vas 5.7 ltrs Xmax 0.28 mm peak VC ¨ª 20 mm http://www.madisound.com/catalog/pro...roducts_id=268
Website |
#2 |
24W.
but is that continuous or peak or intermittant or ? 24W is about 14dbW. add that to 90db/w/m and you get a maximum of about 104db/m subtract 8db for a sensible listening distance and add 3db for a pair. and you have a maximum average listening SPL of about 79db. Not too bad for a little 4inch driver. But it won't produce much bass volume.
regards Andrew T. |
#3 |
Very approximately with 1kHz c/o point about 1/3 full power. (Depends on the type of music - amount of bass power.) That is around 75W continuous weighted noise type signal. In practice music is dynamic not continuous, so a long as the amplifier is not driven deep into clipping I'd say power handling would be around 150W unclipped programme. |
| Multiple driver MMT calculation question | JohnIsBaffled | Multi-Way | 3 | 4th August 2008 01:31 PM |
| calculation of output power?.. | clovi_kate | Solid State | 27 | 19th June 2007 08:26 PM |
| Calculation of power required by driver | PaulHilgeman | Solid State | 0 | 6th May 2003 02:05 PM |
| Calculation of RMS power output? | protos | Solid State | 47 | 1st February 2003 08:11 AM |
| Problems with power calculation in amp. | Duo | Solid State | 8 | 1st July 2002 12:22 PM |
| Page generated in 0.06439 seconds (73.33% PHP - 26.67% MySQL) with 10 queries |
