Old 10th November 2007, 03:00 PM   #1
Default 10"woofer Recommendations
Hi guys...I am trying to find a suitable woofer driver to match sensitivuty and sound wise with my Electrovoice "Force" 10" midrange...open to all suggestions...Dave
Old 10th November 2007, 04:51 PM   #2
Speakerholic
Cal Weldon's Avatar
Hi Dave,
I've moved this over to loudspeakers.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 10th November 2007, 07:37 PM   #3
Brett's Avatar
Default Re: 10"woofer Recommendations
You're probably not going to find anything else that will plug and play into the same xover and enclosure.
If it's a scratch build or a mod job, some more details of what you want would be nice. To me a 10" is a midrange.
Old 10th November 2007, 09:45 PM   #4
I want to find a suitable 10 or 11" driver to match with my force driver per channel...a friend of mine who's system I admire has already done this and was hoping to do the same thing...instead of using 10" drivers he is using the Force 15"....Force 10" specs: 98 db eff,qts .38,fs 65 hz,8 ohm imp....thanx in advance...Dave
Old 10th November 2007, 09:48 PM   #5
Oh I forgot to mention that he is using doubled Audiosphere research 15" drivers for freq below 24 hz
Old 10th November 2007, 10:19 PM   #6
tinitus is online now tinitus  Europe
So you should know what it takes to get there
Old 11th November 2007, 12:22 AM   #7
But I suppose that a single 18" with lowish Fs would be fine too
Old 11th November 2007, 12:23 AM   #8
Brett's Avatar
The Beyma 18LX60 is nice in that application.
Old 11th November 2007, 02:01 AM   #9
Right, I admit I am also looking more and more into the Beymas at the moment
As distortion, or should I say lack of, has become so popular I may choose 18G40 or even the big 21L50
I am thinking of adding some weight to the cone to get Fs down
Old 11th November 2007, 02:59 AM   #10
Peavey 18" Low Rider is very comparable with these woofers, if not better in many respects, and of course, perhaps not quite as good in others. Might not extend quite as low as something like the 18LX60 either, but it's not far off either, and certainly A LOT better than most in its category. All this for a MUCH cheaper price. And if modifying drivers like this is your thing, well then that'd just make it that much more of a capable driver for money well spent.
Closed back midrange drivers 4" maybe 3" - recommendations please RobWells Multi-Way 2 22nd February 2007 04:59 PM
Recommendations for 6.5-8" woofer/midrange as a dipole Samppo Multi-Way 11 3rd October 2006 12:55 PM
WTB: Focal & Audiom & Volts 11", 12", 13", 15" woofer gengis Swap Meet 0 17th March 2005 02:29 AM
"Forgiving" Speaker recommendations needed bigerik Multi-Way 0 30th November 2004 03:37 AM
Need sub woofer driver recommendations griff Subwoofers 4 27th December 2001 06:24 PM
Page generated in 0.09325 seconds (77.29% PHP - 22.71% MySQL) with 10 queries
