Old 8th November 2007, 06:21 PM   #1
Default spl trace
Hello,
I have a problem with SPL trace. The trace stop before the frequency I have choosen, before reaching 20.000 it says"Specifed limit trace has been reached".
Other time it goes well beyond the end of the graph.
I'm triying to trace the FT of the Fostex FF225K and the FT17H.
What can I do?
Old 8th November 2007, 07:48 PM   #2
jnb is offline jnb  Australia
Did you set the upper/lower dB and upper/lower (left/right) frequencies before starting the trace?
Old 8th November 2007, 08:14 PM   #3
yeah
Old 8th November 2007, 11:10 PM   #4
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
My traces usually go a little over the limit line. I think it has to do with the image scaling to make the image fit the screen that screws up the proportions a bit. Open your trace up in SPLView and compare. Do they match? Also, after to set you limits, just move your cursor around and see if the numbers at the bottom line up well with the graph. If they do, then I wouldn't worry too much.
I had a heck of a time tracing an impedance plot that was on a logarithmic vertical scale. I couldn't get the numbers to match if I set the low impedance to 0.
PCB Trace widths Mark245 Solid State 19 7th July 2009 09:13 PM
help with spl trace mcmahon48 Multi-Way 2 21st April 2009 11:16 PM
Trace Elliot BOCHIN Solid State 5 30th June 2008 10:17 AM
Want SPL Trace software anthony_wg Multi-Way 0 2nd November 2007 01:09 PM
ES-JLH bis: Trace Elvee Solid State 0 27th September 2006 04:42 PM
Page generated in 0.06469 seconds (72.84% PHP - 27.16% MySQL) with 10 queries
