Old 15th January 2008, 08:09 AM   #21
DonM is offline DonM  Canada
Zilch,
In the N800-F there is a variable potentiometer (16 ohms) in series with a fixed resistor of 20 ohms parallel to the HF.
Can I assume in your test the potentiometer was set to its minimum and there was still the fixed resistor in series?
Thanks,
Don
PS. I'm an Accountant
Old 15th January 2008, 09:22 AM   #22
R.I.P.
The variable potentiometer is 25 Ohms, actually, according to the schematic (link @ #15). That was set for no attenuation, for a total of 45 Ohms across the HF driver, and full drive to its terminals, i.e., no resistance in series with the driver.
This I conclude from observing that the SPL levels are essentially superimposed in the VHF, where the filter does not itself appreciably attenuate the drive....
Old 15th January 2008, 10:41 PM   #23
R.I.P.
Found the 8-Ohm Altec N800-8K schematic:
Old 15th January 2008, 11:59 PM   #24
Zilch,
I'm using X-Over Pro 3 to simulate some different scenarios for my Altec 806a & 416. It's not that accurate but does give some indication of the response change when you use different values.
I will input the values from the N-800F that you used and compare the X-Over Pro simulated response to your spl graph posted above for the 806A.
Thanks again for your help.
Don
Wtb:original Vintage Old Speakers ,jensen,altec,heathkit loviz Swap Meet 5 9th May 2009 09:18 PM
Altec 811B horns and Altec 414z 12" Speakers xecluded Swap Meet 0 21st September 2008 06:21 AM
Very nice pair of Altec 515 8G Russellc Swap Meet 4 1st July 2008 05:09 PM
Heathkit AS 101 (aka Altec Lansing Valencia) rdekleer Multi-Way 0 2nd April 2003 05:05 PM
Page generated in 0.07979 seconds (65.99% PHP - 34.01% MySQL) with 11 queries
