Hi
help me How to calculate " BIB Bigger Is Better Speaker Cabinet Design" for focal speaker 5A1.Line length= ?, Zdriver=?,Sm=? Parameters Fs 66.54 Hz Vas 6.56 I 0.23 Ft3 Qts 0.59 Qes 0.64 Qms 7.97 Re 3.30 ohms Sd 86.59 cm2 13 2/5in2 Cas E-09 m5/N Mas 122.57 kg/m4 Ras 6429.58 ohms.ac Cms 623E-6 m/N Mms 9.19 g 0.02 Ib Rms 0.482 Kg/s Ces 463.88 mF Les 12.33 mH Res 40.93 ohms BI 4.44 N/A SPL 86.6 dB/W/m |
#2 |
If you look on the main BIB thread you will find several spreadsheets which will give you the ~optimal dimensions. This is mine: http://www.diyaudio.com/forums/showt...79#post1306879
#3 |
Very, very thanks Scottmoose.Thats no problem.
good work, |
| Focal Car Seps - Cabinet Suggestions | weng | Multi-Way | 9 | 9th August 2008 04:16 PM |
| Looking For Focal audiom 7k2 or focal 7k6411 | jasonyap | Multi-Way | 0 | 29th March 2007 06:46 AM |
| Focal 7 N 401 | Mango | Multi-Way | 1 | 16th November 2006 09:13 AM |
| MTM design FOCAL 6W4311 AND FOCAL Focal TC120 Tdx2 | Bas Horneman | Multi-Way | 1 | 5th February 2003 04:21 PM |
| Page generated in 0.06023 seconds (78.07% PHP - 21.93% MySQL) with 10 queries |
