Old 7th November 2007, 07:05 AM   #1
Default good midrange
Hello there, I currently have 12m revelator midrange and I am look for a replacement. It must be better, same pricerange(or a bit more) as 12m, higher SPL and/or higher power.
I have an active system with
2x21W8555-01 with Aleph 5
12M4631g00 revelator with Aleph 3
D9505/990000 revelator with Aleph 3
active system, first pictures
Ok, any suggestions?
aaronboumans at hot mail dot com
Old 7th November 2007, 02:22 PM   #2
sdclc126's Avatar
I would only replace a Revelator with another Revelator - I don't think there's anything better - subjectively maybe, given personal preferences, but not in terms of distortion measurements.
Soft Dome
Old 7th November 2007, 02:45 PM   #3
I agree, but the spl of the 12m is not that great and also the 40W.
Most of the time I play classical music on a live-concert level(very loud!) and I dont think the single 12m is enough (and I don not want to use 2 drivers parallel as the 12m is only 4 ohm)
Old 7th November 2007, 03:07 PM   #4
Jay_WJ is offline Jay_WJ  United States
40W should be power rating without a crossover. Your midrange's real power handling and excursion limit should depend on the HPF setting you're using now. I'm pretty sure that your bass drivers' excursion will reach its limit before your midrange's does with most of music materials you listen to.
Old 7th November 2007, 03:39 PM   #5
tinitus is online now tinitus  Europe
Its your xo you need to address ... its a 89-90 db driver and should be sufficient
You may need higher xo points, at least 300hz ... what are your xo points and slopes
Well, I suppose with active its a 24db ... try 12db
You may also need to raise upper xo point ... fore some reason the revelators seem to sound a bit lazy with low xo point ... well, I only know the 15W, which can sound very distorted and quite awfull ... but its all in the crossover
Old 7th November 2007, 03:42 PM   #6
Banned
Default Re: good midrange
There are plenty of excellent sounding pro drivers with 96+ db/w sensitivity out there.
Please point me to a distortion graph for this. I'd love to see it!
Old 7th November 2007, 03:48 PM   #7
Thats not too hard too find
http://www.zaphaudio.com/smalltest/compare.html
Like I said ... higher xo point
Old 7th November 2007, 05:31 PM   #8
I am crossing at 350 and 3500 hz with 24dB LR.
I do like the sound of the 12m but it cannot be played as loud (breakup?) as I want and the tweet and woof can!
So must I build an new case with more 12m's and maybe an extra Aleph? I don't want to.... I want an alternative speaker with more power and same quality as 12m.
Magnetar; please name some?
Old 7th November 2007, 05:59 PM   #9
Banned
The Audax PR170MO comes to mind -
Look Here
Very high sensitivity, low distortion and smooth to 3-4k. It can be crossed at 300 but 400 is better. Sounds best on an open baffle.
These are very good - I never had the Scan Speak - Still waiting on a distortion graph?
Old 7th November 2007, 06:23 PM   #10
Still waiting on distortion graphs ?? ... thats what the link to Zaph was good fore ... its all there
I need help with a good midrange ben62670 Multi-Way 4 17th December 2008 09:49 PM
Best midrange good price jardag Multi-Way 3 5th January 2006 08:18 AM
Need a good midrange keltor Multi-Way 1 21st May 2004 10:18 PM
Looking for a good full midrange. EternaLightWith Multi-Way 80 24th July 2003 03:50 PM
Page generated in 0.09869 seconds (83.99% PHP - 16.01% MySQL) with 11 queries
