Old 4th November 2007, 02:54 PM   #1
freddi is offline freddi  United States
freddi's Avatar
Default are notch filters for compression driver sometimes helpful w. coax?
lets say a HF driver is runing on a coaxial -can putting a notch at ~driver/horn resonance help improve sonics? what works?
Old 21st November 2007, 07:10 PM   #2
MarkMcK is offline MarkMcK  United States
If the output is up at driver/horn res, then a notch filter, properly set for magnitude will help.
Things get complicated, however, because the notch filter with change the apparent acoustic point of origin. I assume we are close to the crossover frequency the driver/horn res point. If so, then the change in the acoustic center for the driver/horn can change how the two drivers sum. The two together might get better or they might get worse.
Can you test to see what the system is doing now?
Mark
Old 21st November 2007, 07:35 PM   #3
If you're using a coaxial right now, I'd simply be curious to know what it is, and how you're using it.
Active notch filters neutron7 Full Range 2 19th November 2006 11:51 AM
Multiple notch filters? Mikael Abdellah Full Range 2 25th August 2006 05:09 PM
Help on series notch filters. bowdown Multi-Way 1 9th March 2005 05:51 AM
Page generated in 0.07087 seconds (75.51% PHP - 24.49% MySQL) with 10 queries
