Martin Sound ~ Anyone seen this?
Old 4th November 2007, 07:33 AM   #1
BHTX is offline BHTX  United States
BHTX's Avatar
Default Martin Sound ~ Anyone seen this?
..Especially this one, although while attempting to model it in WinISD Pro with what little information they provide, it gave me a much lower sensitivity of 83.23 dB. I'm sure they're probably not fantastic by any means, but I'm wondering just how decent they really are. Anyway, I've been on the look out for a driver that's similar yet better than the Dayton Series II 15's for a similar price, hence my possible interest in these drivers. Crossed over 100-200 Hz, very clean, any freq response nasties as far as possible from the xover point, sealed cabinet with EQ, lowest FS possible, 8 ohms (will use 2 per cabinet), no foam surrounds, good sensitivity, 8+ mm xmax. If you have any good recommendations, post 'em. If nothing else turns up, then the Dayton Series II's it is..
http://www.martinsoundpro.com/moreinfo.asp?id=170
http://www.martinsoundpro.com/upload/item/1844.pdf
Sugg. List $ 119.00
OUR PRICE : $ 87.26/ea.
Just to refreshify anyone's memory who might need it:
http://www.partsexpress.com/pe/showd...number=295-130
http://www.partsexpress.com/pdf/295-130s.pdf
Old 4th November 2007, 03:00 PM   #2
wigginjs is offline wigginjs  United States
wigginjs's Avatar
Perhaps this popular Pyle driver?
http://www.partsexpress.com/pe/showd...number=292-218
I've never used it myself, but it seems like it could fit your needs...
Old 4th November 2007, 03:33 PM   #3
freddi is offline freddi  United States
freddi's Avatar
15269/1844 (151269 Eminence) is a nice woofer - Le is kinda high at ~4mH
Old 4th November 2007, 11:06 PM   #4
BHTX's Avatar
Hi freddi. Looks like you've had some personal experience with this woofer? Would you happen to remember how accurate the specifications were? I'm a little confused with the VAS.. 1.27 cubic feet? Is that correct?? With these specs in WinISD pro, I'm getting a -6 dB EBS alignment with only 2 cubic feet at just over 15 Hz! This can't be right, can it? Any idea?
Old 5th November 2007, 12:11 PM   #5
freddi's Avatar
here's Martin's old spec plus that model's spec from Eminence
01-SPEC 151269 04-DATE 03/14/95
02-PART # OBS/1844
03-MODEL # 1525F5637
05-RE OHMS 6.21 13-FS HZ 23.40
06-LE MH 4.10 14-MMS GMS 103.30
07-QM 11.63 15-CMS mm/N .4472
08-QE .350 16-RMS NS/M 1.3068
09-QT .340 17-VAS LTRS 460.63
10-XMAX MM 9.10 18-SD SCM 856.34
11-BL TM 16.42 19-EBP 66.8
12-EFF % 1.63 20-SPL dB 94.1
_____________________
15in. Bass Woofer / 15269
Made in USA &149, Santoprene Rubber Surround &149, Extra thick treated paper cone Specifications Diameter-15.187in./Impedance-8ohm/Frequency Response-20-1200kHz/Power-300W/Rms/Dc Resistance-6.21ohm/Spl-94dB/Magnet-56oz/Voice coil-2.5in./FS-23.4Hz/VAS-16.27ft3/Qms-11.63/Qes-0.35/Qts-0.34/Xmax-9.1mm/Zmax-212ohm/Depth-6.75in./Hole Cut-14in./Mounting Centers-14.75in./Weight-13lbs
Old 5th November 2007, 09:28 PM   #6
BHTX's Avatar
Thanks so much!
..Looks like they left the 6 out of "16.27" on their PDF for the VAS.
Martin Sound ~ Anyone seen this?Hide this!Advertise here!
martin logan's dsiroky Pass Labs 17 16th April 2007 11:13 AM
Which wideband/FR sound great with Dean Martin? freddi Full Range 2 4th January 2007 11:47 PM
More open and dynamic sound mod for Martin Logan Monolith III georgehifi Planars & Exotics 0 23rd December 2005 01:01 PM
martin logan csl flodge Planars & Exotics 12 13th November 2005 03:59 PM
Copyright ©1999-2017 diyAudio
