Hi Guys
I am looking for information to build a pair of cabinet for my two 15" woofers. Does anyone out there has building information please send it to me. Thanks. |
#2 |
#3 |
Hi BHTX
Do you have any building instruction of cabinets for 15" woofer to send me? If so please send and you will be high appreciated. Thanks |
#4 |
Hi HKC,
Please specific which model of 15" woofer your using, or provide us its T/S parameters Otherwise, I'm afraid no one here is able to help without these information..... |
#5 |
Hi banana
It is a Scott 15" alnico woofer. I do not know the T/S Parameters. What is it? Please advice. Thanks |
#6 |
It is pretty much impossible to build a proper cabinet for a speaker unless you have some numbers known as the Thielle Small Parameters (I may have the spelling wrong).
These numbers describe various aspects of the drivers performance that determine how it will perform with different boxes loading it. If you don't have the specs from the manufacturer they can be measured but it is somewhat complex (though doable with patience and a little bit of equipment). Do you have any idea what size and style box it was in? Seeing as it is a vintage driver you could try some guesses to see how it goes. First try in in a plain baffle with no back and just vestigial side, bottom, and top plates. Make the baffle about 20" wide and the side and tops about 6"-8" deep. If the bass is adequate you may need go no further. If the bass is very weak then you can try a sealed box ( a ported box is not worth trying without the parameters ). Start by putting some fiberglass insulation in the open back box and putting a back on it. See how it sounds. Now start putting bricks or blocks of wood in to take up some space. If the sound improves keep adding stuff until it no longer improves or starts to get worse. Now you can build a permanent box with that internal volume. If adding stuff makes it worse from the beginning then you probably need to make a bigger box. Without measuring experimentation is the only option left. mike |
#7 |
Try the Karlson for a fun and satisfying project. I like mine very much, dynamics out the wazoo!
It should work well with the Scott drivers, seems to work well with most vintage fifteen inchers. BUT...The suggestion for an open baffle is very valid, especially for the little amount of money and effort required for excellent results...it's been one of the favorite DIY fads of late and it never seems to miss. You can decide to build something else later and incorporate the OB's into the subsequent build as baffles, or cut them into braces.
Fighting the program since 1976. |
#8 |
Hi Mike & Bartek
Thank you for the information. It is very helpful. I will look into it and see what I can do. Best Regards Gary |
| are ultraflex cabinets "tuned"? | asiquis | Multi-Way | 1 | 14th July 2009 10:44 PM |
| Looking to re-house Tannoy 10" DC and 10" woofers in to other cabinets | speedysteve | Multi-Way | 15 | 30th September 2008 03:27 AM |
| Dayton Cabinets used in a "high-end" design?? | sbrtoy | Multi-Way | 5 | 21st September 2008 02:46 PM |
| Onken Woofer Cabinets | hifish | Swap Meet | 0 | 4th January 2007 08:12 PM |
| WTB: Focal & Audiom & Volts 11", 12", 13", 15" woofer | gengis | Swap Meet | 0 | 17th March 2005 02:29 AM |
| Page generated in 0.09525 seconds (79.79% PHP - 20.21% MySQL) with 10 queries |
