I'd like to know if its plausible to seperate this crossover network in order to turn it in to bi-wire/passive bi-amping capable. Please see attached schematic and info.
I'm thinking if I were to seperate the network at the red marking lines this should accomplish my goal. The only obvious problem I can see is that the K-1 polyswitch/ L1 lamp protection circuit is only in circuit with the woofer. If its plausible to seperate what must I do in order to keep this type of protection circuit for both limbs? Also, how are the high frequencies filtered from the woofer? |
#2 |
Did it Himself
Are you sure that's drawn correctly? By that diagram the woofer is run full range and the tweeter crossover is a little odd. To convert it to bi-wire simply unhook the YL wire from the board and attach it to your new input terminal.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 | |
Exactly. Easy as cake. It is a strange arrangment, with the fullrange woofer and the 2 tweeters out of phase. But hey, if it works, why not?
Take the Speaker Voltage Test! |
#4 |
Thanks for the resposes so far. Unhooking the yellow wire would accomplish what I have already described but put the polyswitch and lamp protecton in the tweeters circuit. Looking for some options with regards to the protection also. It IS drawn correctly.
#5 |
#6 |
Did it Himself
The polyswitch and lamp is designed to protect the tweeter, as it's tweeter that gets blown by clipping. If you move it to the woofer it might as well be thrown in the bin.
#7 |
I don't think thats correct Richie. In the first schematic the polyswitch is before both the woofer and tweeter. The first lamp when the polyswitch opens would attenuate the signal for the woofer also and the second lamp attenuates further the tweeters or am I missing something?
| 4th BP experts? | danielm | Subwoofers | 4 | 20th July 2009 04:47 PM |
| DHT experts, i need your help | Cassiel | Tubes / Valves | 10 | 25th February 2009 01:42 PM |
| Crossover experts, help me please. | ShinOBIWAN | Multi-Way | 9 | 21st May 2004 12:02 AM |
| passive crossover related questions- calling all experts! | nobody special | Multi-Way | 2 | 7th November 2003 08:04 PM |
| Crossover Experts! Hole in 12dB/octave, (both sides), response? Help!! | kelticwizard | Multi-Way | 14 | 17th July 2002 08:45 AM |
| Page generated in 0.08457 seconds (75.38% PHP - 24.62% MySQL) with 10 queries |
