Hi all,
If I enter: Bass: -35mm Mid: -15mm Tweeter: 0mm instead of: Bass: -40mm Mid: -20mm Tweeter: -5mm Thus same relative offsets between all the drivers BUT the phase tracking is very different from 5 to 20Khz. Do you know WHY? Thanks.
crazyhub |
#2 |
Relative phase (degree difference between drivers) should not be different. The resulting SPL sum should not be different, either. By using extra -5mm offset (i.e., drivers farther from mic), acoustic phase of each driver will have a faster turn. That's why they look different. Fast phase turns make it harder to look at phase tracking.
#3 | |
Jay wrote:
crazyhub |
#4 |
Without pictures, I would assume that the issue is "excess phase"
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#5 | |
Ron e wrote:
crazyhub |
#6 |
With a PC, you just hold down Ctrl and press the Print Screen" button.
Then you open "Paint" and select edit\paste from the menu, or just press Ctrl+V. If you have some other computer, do a search on "print screen" or "screen capture".
#7 |
Thanks Ron for my computer education! 50 years old and 47years without computer doesn't help
Here are the two pictures ![]()
crazyhub |
#8 |
Just excess phase. The extra 5mm of time of flight causes the high frequencies to be delayed for a greater proportion of their wavelength, which is why there is little to no effect at low frequencies and a larger effect as frequency increases. As simple as that. If there were inter-driver "phase tracking" problems, the frequency response would change.
#9 |
Ron's explanation is correct, and your understanding also seems correct. SW adds/subtracts delay to each driver's acoustic phase across frequencies before computing the SPL sum of drivers. When the offset is set to 0, it uses the phase in each driver's FRD file as is.
-jAy |
#10 |
Jay and Ron,
Thank you for your helpfull explanations.
crazyhub |
| FFT size in SpeakerWorkshop | jm_kzo | Multi-Way | 2 | 9th July 2008 07:48 AM |
| phase compensation due to driver offsets | DcibeL | Multi-Way | 51 | 1st June 2008 06:35 PM |
| Speakerworkshop question | kro5998 | Multi-Way | 2 | 25th June 2006 06:18 PM |
| SpeakerWorkshop again | Dave Jones | Multi-Way | 19 | 17th June 2004 05:34 PM |
| Page generated in 0.10970 seconds (79.85% PHP - 20.15% MySQL) with 10 queries |
